[Swift-user] CPU was not in the block (Swift 0.96)
Michael Wilde wilde at anl.gov
Tue Mar 10 08:56:16 CDT 2015
Jason, we'll almost certainly need a log for this; feel free to send a
pointer, off-list.
Ideally for the run that produced the traceback below.
What happens when this occurs?  Does the run continue?  Any observable
ill effects?
- Mike
On 3/10/15 8:47 AM, Jason James Pitt wrote:
> Hi Everyone,
> I've sporadically seen the following exception (or similar) sporadically in some of the runs I've been performing recently. Any sense of what this may mean and is there something I can do on my end to prevent it? I can pass along the logs if that'd be helpful (though this particular run is still active). Thanks!
> Jason
> CoasterService fatal error:
> java.lang.Throwable
> 	at org.globus.cog.abstraction.coaster.service.job.manager.Block.remove(Block.java:209)
> 	at org.globus.cog.abstraction.coaster.service.job.manager.Cpu.jobTerminated(Cpu.java:115)
> 	at org.globus.cog.abstraction.coaster.service.job.manager.Cpu.statusChanged(Cpu.java:433)
> 	at org.globus.cog.abstraction.impl.execution.coaster.NotificationManager.notificationReceived(NotificationManager.java:117)
> 	at org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:81)
> 	at org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:112)
> 	at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:590)
> 	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:240)
> 	at org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:116)
> 	at org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:75)
> java.lang.Throwable
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
More information about the Swift-user mailing list
