[Swift-user] CPU was not in the block (Swift 0.96)
Jason James Pitt pittjj at uchicago.edu
Tue Mar 10 08:47:13 CDT 2015
Hi Everyone,
I've sporadically seen the following exception (or similar) sporadically in some of the runs I've been performing recently. Any sense of what this may mean and is there something I can do on my end to prevent it? I can pass along the logs if that'd be helpful (though this particular run is still active). Thanks!
Jason
CoasterService fatal error:
java.lang.Throwable
	at org.globus.cog.abstraction.coaster.service.job.manager.Block.remove(Block.java:209)
	at org.globus.cog.abstraction.coaster.service.job.manager.Cpu.jobTerminated(Cpu.java:115)
	at org.globus.cog.abstraction.coaster.service.job.manager.Cpu.statusChanged(Cpu.java:433)
	at org.globus.cog.abstraction.impl.execution.coaster.NotificationManager.notificationReceived(NotificationManager.java:117)
	at org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:81)
	at org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:112)
	at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:590)
	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:240)
	at org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:116)
	at org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:75)
java.lang.Throwable
More information about the Swift-user mailing list
