[Swift-user] trunk-cobalt block task ended prematurely
Mihael Hategan hategan at mcs.anl.gov
Mon Mar 2 16:33:09 CST 2015
Well, we need to figure out why. Since the qsub command line is in the
swift log, and the qsub command line should reflect the setting, it
would be useful if you posted the swift log.
Mihael
On Mon, 2015-03-02 at 16:27 -0600, Ketan Maheshwari wrote:
> For workerlogs, I am trying:
>  app.bgsh {
>         executable: "/home/ketan/SwiftApps/subjobs/bg.sh"
>         maxWallTime: "00:04:00"
>         env.ENABLE_WORKER_LOGGING="TRUE"
>         env.WORKER_LOGGING_LEVEL="DEBUG"
>         env.WORKER_LOG_DIR="/home/ketan/workerlogs"
> Does not seem to trigger logging.
> Thanks,
> Ketan
> On Mon, Mar 2, 2015 at 4:07 PM, Hategan-Marandiuc, Philip M. <
> hategan at mcs.anl.gov> wrote:
> > I would recommend enabling worker logging to see if we get any info from
> > the worker process. Could be some simple thing, like the wrong IP
> > address.
> > Mihael
> > On Mon, 2015-03-02 at 15:47 -0600, Ketan Maheshwari wrote:
> > > I trying to run on BG/Q with local:cobalt with trunk but Swift crashes
> > with
> > > the following error:
> > > Caused by: Exception in bgsh:
> > >     Arguments: [/home/ketan/SwiftApps/subjobs/mpicatsnsleep/mpicatnap,
> > > /gpfs/mira-home/ketan/SwiftApps/subjobs/mpicatsnsleep/./data.txt,
> > /gpfs/mira-home/ketan/SwiftApps/subjobs/mpicatsnsleep/./outdir/f.0002.out,
> > > 1]
> > >     Host: cluster
> > >     Directory: catsnsleepmpi-run001/jobs/b/bgsh-3nq3uc5m
> > > exception @ swift-int-staging.k, line: 165
> > > Caused by:
> > > exception @ swift-int-staging.k, line: 160
> > > Caused by: Block task failed: 0302-2109420-000000 Block task ended
> > > prematurely
> > > In the log, I see the qsub call being made and a jobid is returned.
> > > However, I could not figure what is the cause for the task to fail.
> > > One more thing I noticed when translating from old sites conf to new is
> > > that the new conf did not accept the property "globus:mode = script".
> > > A full run log is attached. Thanks for any suggestions.
> > > Thanks,
> > > Ketan
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
