[Swift-user] trunk-cobalt block task ended prematurely
Ketan Maheshwari
ketan at mcs.anl.gov
Mon Mar 2 16:27:27 CST 2015
For workerlogs, I am trying:
app.bgsh {
executable: "/home/ketan/SwiftApps/subjobs/bg.sh"
maxWallTime: "00:04:00"
env.ENABLE_WORKER_LOGGING="TRUE"
env.WORKER_LOGGING_LEVEL="DEBUG"
env.WORKER_LOG_DIR="/home/ketan/workerlogs"
Does not seem to trigger logging.
Ketan
On Mon, Mar 2, 2015 at 4:07 PM, Hategan-Marandiuc, Philip M. <
hategan at mcs.anl.gov> wrote:
> I would recommend enabling worker logging to see if we get any info from
> the worker process. Could be some simple thing, like the wrong IP
> address.
> Mihael
> On Mon, 2015-03-02 at 15:47 -0600, Ketan Maheshwari wrote:
> > I trying to run on BG/Q with local:cobalt with trunk but Swift crashes
> with
> > the following error:
> > Caused by: Exception in bgsh:
> > Arguments: [/home/ketan/SwiftApps/subjobs/mpicatsnsleep/mpicatnap,
> > /gpfs/mira-home/ketan/SwiftApps/subjobs/mpicatsnsleep/./data.txt,
> /gpfs/mira-home/ketan/SwiftApps/subjobs/mpicatsnsleep/./outdir/f.0002.out,
> > 1]
> > Host: cluster
> > Directory: catsnsleepmpi-run001/jobs/b/bgsh-3nq3uc5m
> > exception @ swift-int-staging.k, line: 165
> > Caused by:
> > exception @ swift-int-staging.k, line: 160
> > Caused by: Block task failed: 0302-2109420-000000 Block task ended
> > prematurely
> > In the log, I see the qsub call being made and a jobid is returned.
> > However, I could not figure what is the cause for the task to fail.
> > One more thing I noticed when translating from old sites conf to new is
> > that the new conf did not accept the property "globus:mode = script".
> > A full run log is attached. Thanks for any suggestions.
> > Thanks,
> > Ketan
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150302/cbb49c3b/attachment.html>
More information about the Swift-user
