[Swift-user] Swift/T+Coasters Usage
Justin M Wozniak wozniak at mcs.anl.gov
Thu Jun 25 16:53:45 CDT 2015
Ah- you need to set environment variable TURBINE_COASTER_WORKERS=1.
I will improve the doc and the error message.
On 6/25/2015 5:32 PM, Jacob Taylor wrote:
> I am trying to use Swift/T+Coasters which I realize is not fully
> integrated. I have been able to get the Coasters service running
> locally, but whenever I try to execute any script that tries to
> dispatch to the Coasters service, it gives me the following error message
>     Executor COASTER has no assigned workers
>         while executing
>     "error "Executor $exec_name has no assigned workers""
>         (procedure "turbine::check_can_execute" line 6)
>         invoked from within
>     "turbine::check_can_execute COASTER"
>         (file "./swift-t-h.b4l.tic" line 127)
> and I have no idea what the problem is. I can send my log files, my
> config files, and the script itself if it will help.
> The documentation for using the two together is not very clear, do I
> need to manually launch the Coasters workers? Or should the service
> automatically launch them for me?
> Also, to clarify, for properly linking Coasters and Swift/T in the
> exm-settings.sh file before building, should the COASTER_INSTALL
> environment variable point to the installation directory or the source
> directory?
> --Jacob Taylor--
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150625/1412bbea/attachment.html>
More information about the Swift-user mailing list
