[Swift-user] import position in swift script
Mihael Hategan
hategan at mcs.anl.gov
Thu Jun 18 19:01:01 CDT 2015
On Thu, 2015-06-18 at 23:54 +0000, Max Hutchinson wrote:
> That params struct sure looks a lot like a json dict. How about `params =
> readJSON("debug.json");`?
Not very far from our plans. If you scroll to the I/O section in
https://github.com/swift-lang/swift-k/wiki/StandardLibrary, there's a
mention of that.
Mihael
> On Thu, Jun 18, 2015 at 3:26 PM Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > On Thu, 2015-06-18 at 19:48 +0000, Max Hutchinson wrote:
> > > I agree that it is a no interface function call. Maybe this is also
> > > helpful with not needing to explicitly collect outputs to get staged out?
> > Good point. We, more or less, require that the app, perhaps through a
> > wrapper script, fully define its interface through the command line. On
> > the other hand, magical matching is allowed. If you have an output
> > carefully mapped to what the application produces, it will work even
> > without a wrapper, but it's impossible to make that work if two
> > invocations produce two files with the same name.
> > That should change. The reason it didn't is that we didn't have a good
> > idea about how to make the collect specification nice in the case of
> > non-trivial file lists.
> > > My understanding is that If run.swift contains a bunch of nested loops,
> > one
> > > would have declare a bunch of [auto] outputs and remember to append
> > > everything to them (or they could be considered tmps and not staged out).
> > > There's value to being forced to be thoughtful, but it might also be nice
> > > to start with the trailing import while prototyping/debugging a script
> > and
> > > then switch to a wrapper after the dust has settled.
> > I'd rather add code to allow mapping in struct expressions, so that you
> > could write something like this:
> > params = {
> > prefix: "debug",
> > json: <"debug.json">,
> > test = sweep(params);
> > and perhaps:
> > with (params) {
> > > I'm focusing on direct staging, so the wrapper was straightforward. For
> > > reference:
> > > https://github.com/maxhutch/nek-swift/blob/alcf/debug.swift
> > > https://github.com/maxhutch/nek-swift/blob/alcf/nek.swift
> > > If imports are only going to be supported in the preamble, could that be
> > > added to the docs?
> > > http://swift-lang.org/guides/trunk/userguide/userguide.html#_imports
> > We're in the process of revamping the docs. It will be in there.
> > Mihael
More information about the Swift-user
