[Swift-user] output file array
Ketan Maheshwari
ketan at mcs.anl.gov
Tue Jan 6 13:04:09 CST 2015
Hi Mike,
The app is creating the file but the way the app is invoked, the filename
does not appear in the command-line. It creates the file at the top level,
so just afile.txt.
However, since there are many calls to the app, to avoid this file being
overwritten, I need to put this file into a separate directory which is why
I am using directory outdirN.
I was thinking if it is possible for Swift runtime to find from the app
definition that the file _appout is expected output similar to stdout and
move the file to the outdirN (again similar to stdout).
Ketan
On Tue, Jan 6, 2015 at 12:53 PM, Michael Wilde <wilde at anl.gov> wrote:
> Is your app touch_app( ) correctly creating output files of the form
> outdirN/afile.txt?
> From the error message, I suspect that it is not.
> Your app is declared as:
> app (file _stdout, file _stderr, file _appout) touch_app(string _instr){
> t _instr stdout=@_stdout stderr=@_stderr;
> You need to pass filename(_appout) to the app, via its command line, so
> that it knows the correct output filename to create. Then you need to
> ensure that the app does indeed create that file.
> - Mike
> On 1/6/15 11:23 AM, Ketan Maheshwari wrote:
> Trying trunk for this pattern.
> A toy application invoked over a foreach loop that creates an output
> file, an stdout and an stderr files.
> The files are mapped into an output directory named with the loop index
> as suffix so that the files do not get overwritten:
> foreach i in [0:9]{
> file out<single_file_mapper; file=strcat("outdir", i, "/std.out")>;
> file err<single_file_mapper; file=strcat("outdir", i, "/std.err")>;
> file appout<single_file_mapper; file=strcat("outdir", i, "/afile.txt")>;
> (out, err, appout) = touch_app("Hello");
> The stdout and stderr files correctly ends up in their respective
> directories but the app generated file does not.
> I see following error message:
> Execution failed:
> Exception in t:
> Arguments: [Hello]
> Host: edison1
> Directory: touchafile-run001/jobs/t/t-ffv33r2m
> exception @ swift-int-staging.k, line: 165
> Caused by: The following output files were not created by the application:
> outdir4/afile.txt
> Any suggestions for fixing this?
> Attached is the test directory with sources and executable with rundir.
> Thanks,
> Ketan
> On Mon, Dec 22, 2014 at 5:14 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>> Hi,
>> I don't think 0.95 supports dynamic arrays output from apps. You will
>> need trunk/0.96 for that.
>> Mihael
>> On Mon, 2014-12-22 at 15:37 -0600, Ketan Maheshwari wrote:
>> > Hi Mihael,
>> > This is with Swift 0.95.
>> > Thanks,
>> > Ketan
>> > On Sun, Dec 21, 2014 at 2:40 PM, Hategan-Marandiuc, Philip M. <
>> > hategan at mcs.anl.gov> wrote:
>> > > Hi Ketan,
>> > > Sorry for the delay. Is this trunk or 0.95?
>> > > Mihael
>> > > On Wed, 2014-12-17 at 14:26 -0600, Ketan Maheshwari wrote:
>> > > > Hi,
>> > > > I am dealing with a workflow pattern where an app expects multiple
>> output
>> > > > files with a pattern.
>> > > > The app signature is:
>> > > > app (file[] _wrfout, file _out, file _err) wrf_app (file _wrf_in,
>> file[]
>> > > > _tbl, file[] _ozone, ...)
>> > > > wrf stdout=@_out stderr=@_err;
>> > > > The _wrfout files are the app result files which follows a pattern:
>> > > wrfout_*
>> > > > So, I am invoking the application in a foreach loop as:
>> > > > foreach i in [0:2]{
>> > > > file[] wrfout<simple_mapper; location=strcat("outdir",i),
>> > > > pattern="wrfout_*">;
>> > > > file wrfstdout<single_file_mapper; file=strcat("outdir", i,
>> > > "/std.out")>;
>> > > > file wrfstderr<single_file_mapper; file=strcat("outdir", i,
>> > > "/std.err")>;
>> > > > (wrfout, wrfstdout, wrfstderr) = wrf_app (wrfin, tbl, ozone, tr,
>> data,
>> > > > gribmap, namelist, co2_trans, input_sounding);
>> > > > The script hangs at runtime with the following messages:
>> > > > No events in 1s.
>> > > > Finding dependency loops...
>> > > > Waiting threads:
>> > > > Thread: R-6-0-4, waiting on wrfout (declared on line 50)
>> > > > swift:stageOut, wf.edison, line 134
>> > > > swift:execute, wf.edison, line 123
>> > > > wrf_app, wf.edison, line 242
>> > > > Thread: R-6-2-4, waiting on wrfout (declared on line 50)
>> > > > Thread: R-6-1-4, waiting on wrfout (declared on line 50)
>> > > > Any suggestions?
>> > > > Thanks,
>> > > > Ketan
>> > > > _______________________________________________
>> > > > Swift-user mailing list
>> > > > Swift-user at ci.uchicago.edu
>> > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Swift-user mailing listSwift-user at ci.uchicago.eduhttps://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Michael Wilde
> Mathematics and Computer Science Computation Institute
> Argonne National Laboratory The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150106/e8a003a5/attachment.html>
More information about the Swift-user
