[Swift-user] output file array
    Michael Wilde
    wilde at anl.gov
    Tue Jan  6 12:53:40 CST 2015
Is your app touch_app( ) correctly creating output files of the form
outdirN/afile.txt?
 From the error message, I suspect that it is not.
Your app is declared as:
app (file _stdout, file _stderr, file _appout) touch_app(string _instr){
     t _instr stdout=@_stdout stderr=@_stderr;
You need to pass filename(_appout) to the app, via its command line, so
that it knows the correct output filename to create.  Then you need to
ensure that the app does indeed create that file.
- Mike
On 1/6/15 11:23 AM, Ketan Maheshwari wrote:
> Trying trunk for this pattern.
> A toy application invoked over a foreach loop that creates an output
> file, an stdout and an stderr files.
> The files are mapped into an output directory named with the loop
> index as suffix so that the files do not get overwritten:
> foreach i in [0:9]{
>   file out<single_file_mapper; file=strcat("outdir", i, "/std.out")>;
>   file err<single_file_mapper; file=strcat("outdir", i, "/std.err")>;
>   file appout<single_file_mapper; file=strcat("outdir", i, "/afile.txt")>;
>   (out, err, appout) = touch_app("Hello");
> The stdout and stderr files correctly ends up in their respective
> directories but the app generated file does not.
> I see following error message:
> Execution failed:
> Exception in t:
>     Arguments: [Hello]
>     Host: edison1
>     Directory: touchafile-run001/jobs/t/t-ffv33r2m
> exception @ swift-int-staging.k, line: 165
> Caused by: The following output files were not created by the
> application: outdir4/afile.txt
> Any suggestions for fixing this?
> Attached is the test directory with sources and executable with rundir.
> Thanks,
> Ketan
> On Mon, Dec 22, 2014 at 5:14 PM, Mihael Hategan <hategan at mcs.anl.gov
> <mailto:hategan at mcs.anl.gov>> wrote:
>     Hi,
>     I don't think 0.95 supports dynamic arrays output from apps. You will
>     need trunk/0.96 for that.
>     Mihael
>     On Mon, 2014-12-22 at 15:37 -0600, Ketan Maheshwari wrote:
>     > Hi Mihael,
>     > This is with Swift 0.95.
>     > Thanks,
>     > Ketan
>     > On Sun, Dec 21, 2014 at 2:40 PM, Hategan-Marandiuc, Philip M. <
>     > hategan at mcs.anl.gov <mailto:hategan at mcs.anl.gov>> wrote:
>     > > Hi Ketan,
>     > > Sorry for the delay. Is this trunk or 0.95?
>     > > Mihael
>     > > On Wed, 2014-12-17 at 14:26 -0600, Ketan Maheshwari wrote:
>     > > > Hi,
>     > > > I am dealing with a workflow pattern where an app expects
>     multiple output
>     > > > files with a pattern.
>     > > > The app signature is:
>     > > > app (file[] _wrfout, file _out, file _err) wrf_app (file
>     _wrf_in, file[]
>     > > > _tbl, file[] _ozone, ...)
>     > > >    wrf stdout=@_out stderr=@_err;
>     > > > The _wrfout files are the app result files which follows a
>     pattern:
>     > > wrfout_*
>     > > > So, I am invoking the application in a foreach loop as:
>     > > > foreach i in [0:2]{
>     > > >   file[] wrfout<simple_mapper; location=strcat("outdir",i),
>     > > > pattern="wrfout_*">;
>     > > >   file wrfstdout<single_file_mapper; file=strcat("outdir", i,
>     > > "/std.out")>;
>     > > >   file wrfstderr<single_file_mapper; file=strcat("outdir", i,
>     > > "/std.err")>;
>     > > >    (wrfout, wrfstdout, wrfstderr) = wrf_app (wrfin, tbl,
>     ozone, tr, data,
>     > > > gribmap, namelist, co2_trans, input_sounding);
>     > > > The script hangs at runtime with the following messages:
>     > > > No events in 1s.
>     > > > Finding dependency loops...
>     > > > Waiting threads:
>     > > > Thread: R-6-0-4, waiting on wrfout (declared on line 50)
>     > > > swift:stageOut, wf.edison, line 134
>     > > > swift:execute, wf.edison, line 123
>     > > > wrf_app, wf.edison, line 242
>     > > > Thread: R-6-2-4, waiting on wrfout (declared on line 50)
>     > > > Thread: R-6-1-4, waiting on wrfout (declared on line 50)
>     > > > Any suggestions?
>     > > > Thanks,
>     > > > Ketan
>     > > > _______________________________________________
>     > > > Swift-user mailing list
>     > > > Swift-user at ci.uchicago.edu <mailto:Swift-user at ci.uchicago.edu>
>     https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150106/d21b9a98/attachment.html>
More information about the Swift-user
