[Swift-user] Pointer to Swift tutorials for computational science education and research
Ketan Maheshwari ketan at mcs.anl.gov
Fri Sep 5 20:03:26 CDT 2014
Hi Andrew,
Yes, I remember: thanks for getting back on this.
>From the error message and tc.data, indeed it looks like the executable is
provided as absolute path but somehow Swift is looking into system path and
not finding it. One possibility is that the node on which catnap.sh is
running does not have it installed on the path specified in the tc.data.
Can you also check if catnap.sh has the executable bit set. Less likely
that this is causing the issue though.
Also, from the tc.data line it looks like you are using persistent
coasters. Have started the coaster service beforehand and made sure the
service started correctly without any error messages. Could you indicate
more about your cluster. Depending on the type of cluster, it is possible
that we can run Swift in a non-persistent, implicit coasters mode.
Can you also send the Swift generated log for this run.
Ketan
On Fri, Sep 5, 2014 at 7:16 PM, Andrew Stocker <amstocker at dons.usfca.edu>
wrote:
>  Hi Ketan,
>  I'm not sure if you remember, but myself and my research advisor
> Xiaosheng spoke to you at LBL in Oakland at the beginning of the summer
> about starting to use Swift at our school.   We have been working hard on
> setting it up, and I am trying to get your demo to run but I'm having a
> problem.  For some reason I keep getting the following error when I try to
> run your catsnsleep demo:
>  Execution failed:
> Exception in catnap:
>     Arguments: [5, data.txt]
>     Host: persistent-coasters
>     Directory: catsnsleep-20140905-1702-mihcat06/jobs/u/catnap-utx080xl
>  Caused by:
> Cannot find executable catnap.sh on site system path
> catnap, catsnsleep.swift, line 13
>  However I'm not sure why.  In our tc.data file we have the line:
>  persistent-coasters catnap /usr/local/swift-0.94.1/oakland-demo/catnap.sh
>  which I think should work but obviously something is going wrong.  I
> have been browsing the documentation articles but I can't find anything
> about why this might be happening.  We would greatly appreciate your advice!
>  Regards,
>  Andrew Stocker
> On Fri, Jun 20, 2014 at 12:00 PM, Xiaosheng Huang <xhuang22 at usfca.edu>
> wrote:
>> ---------- Forwarded message ----------
>> From: Ketan Maheshwari <ketan at mcs.anl.gov>
>> Date: Fri, Jun 20, 2014 at 11:45 AM
>> Subject: Re: Pointer to Swift tutorials for computational science
>> To: Xiaosheng Huang <xhuang22 at usfca.edu>
>> Cc: Wilde <wilde at mcs.anl.gov>
>> Hi Xiaosheng,
>>  The tarball is: http://www.mcs.anl.gov/~ketan/oakland-demo.tgz
>>  There is a small README in there which outlines the steps.
>>  Best,
>> Ketan
>> Xiaosheng Huang, Assistant Professor
>> Department of Physics and Astronomy
>> University of San Francisco
>> 2130 Fulton Street, San Francisco, CA 94117-1080
>> Phone: (415) 422-6281
>> E-mail: xhuang22 at usfca.edu
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140905/fe35eb2c/attachment.html>
More information about the Swift-user mailing list
