[Swift-user] Persistent Coasters & 0.95 RC6
Matthew Shaxted Matthew.Shaxted at som.com
Wed Jun 18 13:59:11 CDT 2014
And here is a tar of the run001.log directory…
Sent: Wednesday, June 18, 2014 12:36 PM
To: 'Yadu Nand'
Cc: swift-user at ci.uchicago.edu
Subject: RE: [Swift-user] Persistent Coasters & 0.95 RC6
Hi Yadu, yes it is attached.
Thanks
MATTHEW SHAXTED
SKIDMORE, OWINGS & MERRILL LLP
224 South Michigan Ave.
Chicago, IL 60604
TEL: 312.360.4368
FAX: 312.360.4545
matthew.shaxted at som.com<mailto:matthew.shaxted at som.com>
[cid:image001.png at 01CF8AFD.7B3D7D20]
WWW.SOM.COM<http://www.som.com/>
The information contained in this communication may be confidential, is intended only for the use of the recipient(s) named above, and may be legally privileged. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication, or any of its contents, is strictly prohibited and may be unlawful. If you have received this communication in error, please return it to the sender immediately and delete the original message and any copy of it from your computer system. If you have any questions concerning this message, please contact the sender.
[cid:image002.png at 01CF8AFD.7B3D7D20]
Sent: Wednesday, June 18, 2014 12:31 PM
To: Matthew Shaxted
Cc: swift-user at ci.uchicago.edu<mailto:swift-user at ci.uchicago.edu>
Subject: Re: [Swift-user] Persistent Coasters & 0.95 RC6
Hi Matthew,
Could you mail us a tar ball of your runNNN directory ?
Yadu
On Wed, Jun 18, 2014 at 12:20 PM, Matthew Shaxted <Matthew.Shaxted at som.com<mailto:Matthew.Shaxted at som.com>> wrote:
Hi, I am trying to upgrade my 0.94 persistent-coasters scripts to 0.95, and seem to be experiencing some difficulty when trying to execute coaster jobs. I can run these test scripts locally with no problems.
I have a swift.properties file that is outlined below. I can successfully start-coaster-service using a hosts.txt file. I notice that this process creates a unique sites.xml file but my swift.properties file should match it. I am manually defining the coaster service port to match that in the swift.properties file.
When I try to run the below test.swift script, I am getting the error that looks like below.
Any idea what may be causing this issue?
Swift.Properties File
sitedir.keep=true
wrapperlog.always.transfer=true
site.local {
   tasksPerWorker=8
   taskWalltime=00:15:00
   maxJobs=1
   workdir=/home/som/EnergyPlus/test/work
   filesystem=local
app.local.echoLocal=/bin/echo
site.persistent-coasters {
   jobManager=coaster-persistent:local:local:http://localhost:50200
   tasksPerWorker=8
   maxJobs=1
   filesystem=local
app.persistent-coasters.echoCoast=/bin/echo
site=local,persistent-coasters
test.swift file
app echo (string s) {
   echoCoast s;
echo("HELLO WORLD");
test.swift Error
from the run.log file
swift NO_STATUS_FILE jobid=echoCoast-5135s9sl - Error file missing
2014-06-18 12:13:25,214-0500 DEBUG swift APPLICATION_EXCEPTION jobid=echoCoast-5135s9sl - Application exception: Job failed with and exit code of 127
Command line output
Swift 0.95 RC6 swift-r7900 cog-r3908
RunID: run003
Progress: Wed, 18 Jun 2014 12:13:24-0500
Execution failed:
Exception in echoCoast:
    Arguments: [HELLO WORLD]
    Host: persistent-coasters
    Directory: test-run003/jobs/5/echoCoast-5135s9sl
        exception @ swift-int.k, line: 530
Caused by: Job failed with and exit code of 127
org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 127 (exit code: 127)
        at org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
        at org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
        at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
        at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
        at org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
        at org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 127
(exit code: 127)
MATTHEW SHAXTED
Chicago, IL 60604
TEL: 312.360.4368<tel:312.360.4368>
FAX: 312.360.4545<tel:312.360.4545>
Swift-user mailing list
Swift-user at ci.uchicago.edu<mailto:Swift-user at ci.uchicago.edu>
https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140618/b0889a63/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140618/b0889a63/attachment.png>
Type: image/png
Desc: image002.png
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140618/b0889a63/attachment-0001.png>
Type: application/x-gzip
Desc: run001.tar.gz
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140618/b0889a63/attachment.bin>
More information about the Swift-user mailing list
