[Swift-user] Swift retries despite execution.retries set to 0
Mihael Hategan hategan at mcs.anl.gov
Tue Jan 21 18:46:20 CST 2014
I think this is a problem with how the job status is done combined with
some genuine problem. All failing jobs are marked "Failed but can retry"
at first. Eventually they get to "Failed", but there are some steps
in-between that for some reason are not working properly. I need to
check why.
Mihael
On Tue, 2014-01-21 at 17:44 -0600, David Kelly wrote:
> I tried a local:slurm test with a failing app, and it stopped after one
> failure. The error you're seeing might be specific to ssh-cl.
> Also just wanted to mention that in your sites.xml you have {env.USER}.
> This no longer works in 0.95/trunk. You can do something similar though
> when/if you move to the new config.
> On Tue, Jan 21, 2014 at 4:27 PM, Ketan Maheshwari <ketan at mcs.anl.gov> wrote:
> > Hi,
> > It seems Swift latest trunk attempts to retry failed executions despite
> > the execution.retries property set to 0. A tarred rundir is attached.
> > Thanks,
> > Ketan
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> one failure. The error you're seeing might be specific to ssh-cl.
> {env.USER}. This no longer works in 0.95/trunk. You can do something
> similar though when/if you move to the new config.
> wrote:
>         Hi,
>         executions despite the execution.retries property set to 0. A
>         Thanks,
>         Ketan
More information about the Swift-user mailing list
