[Swift-user] Swift retries despite execution.retries set to 0
David Kelly
davidkelly at uchicago.edu
Tue Jan 21 17:44:53 CST 2014
I tried a local:slurm test with a failing app, and it stopped after one
failure. The error you're seeing might be specific to ssh-cl.
Also just wanted to mention that in your sites.xml you have {env.USER}.
This no longer works in 0.95/trunk. You can do something similar though
when/if you move to the new config.
On Tue, Jan 21, 2014 at 4:27 PM, Ketan Maheshwari <ketan at mcs.anl.gov> wrote:
> Hi,
> It seems Swift latest trunk attempts to retry failed executions despite
> the execution.retries property set to 0. A tarred rundir is attached.
> Thanks,
> Ketan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140121/b0622936/attachment.html>
More information about the Swift-user
