[Swift-user] sites.xml for cloud
David Kelly
davidk at ci.uchicago.edu
Wed Jan 15 13:53:52 CST 2014
Hi Khawaar,
Sorry that you're running into problems. I think the issue is related to
message "Cannot find template for persistent-coasters", which is strange
because that file should be included with Swift. In the place where Swift
is installed, do you see a file called etc/sites/persistent-coasters?
On Wed, Jan 15, 2014 at 12:25 PM, Khawar Ahmad <khawar.ahmad at cern.ch> wrote:
> Hi David,
> I have done these changes. See the conf file below.
> xport WORKER_LOCATION=/home/ubuntu
> export WORKER_HOSTS="192.168.100.3 192.168.100.4"
> export WORKER_MODE=ssh
> export WORKER_USERNAME=ubuntu
> export IPADDR="192.168.100.2"
> export WORKER_LOG_DIR=/home/ubuntu
> export WORKER_LOGGING_LEVEL=DEBUG
> export WORK=/home/ubuntu/work
> export JOBSPERNODE=1
> export JOBTHROTTLE=10
> export SSH_TUNNELING=yes
> setup.sh went fine without errors. see the output below.
> Swift version is Swift 0.94.1 swift-r7114 cog-r3803
> Assuming
> /home/ubuntu/swift-cloud-tutorial/bin:/home/ubuntu/swift-cloud-tutorial/app:
> is already at front of PATH
> Saving /home/ubuntu/.swift/swift.properties in
> /home/ubuntu/.swift/swift.properties.LTCg
> Start-coaster-service...
> Configuration: /home/ubuntu/swift-cloud-tutorial/scs/coaster-service.conf
> Service address: 192.168.100.2
> Starting coaster-service
> Service port: 52871
> Local port: 60572
> Generating sites.xml
> Starting worker on 192.168.100.3
> Starting worker on 192.168.100.4
> However, the sites.xml file after part03 are empty. see the output below.
> ubuntu at uwe-vm1:~/swift-cloud-tutorial$ more part0*/sites.xml
> part01/sites.xml
> <?xml version="1.0" encoding="UTF-8"?>
> <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
> <pool handle="localhost">
> <execution provider="local" />
> <profile namespace="karajan" key="jobThrottle">0</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> <filesystem provider="local"/>
> <workdirectory>.swift/tmp</workdirectory>
> <profile namespace="swift" key="stagingMethod">local</profile>
> </pool>
> </config>
> part02/sites.xml
> </pool>
> </config>
> part03/sites.xml
> </pool>
> </config>
> part04/sites.xml
> part05/sites.xml
> part06/sites.xml
> In the tutorial, part4 onwards is described as running on compute nodes
> and apps file has entry “cloud sh /bin/bash”, however, I could not see how
> “cloud” would be resolved.
> This is why, I could not run examples part03 onwards. Any help?
> Regards,
> Khawar
> On 15 Jan 2014, at 16:17, David Kelly <davidk at ci.uchicago.edu> wrote:
> Hi Khawar,
> For running with the cloud tutorial, all the settings are defined in a
> file called scs/coaster-service.conf. The only things you should need to
> change there is the list of IP addresses, the remote username, and remote
> directories to use.
> When you run the command "source setup.sh", it should start the workers on
> remote sites and create a sites.xml file in each the part directories. Are
> you getting any errors when you run "source setup.sh"?
> Thanks,
> David
> On Wed, Jan 15, 2014 at 9:34 AM, Khawar Ahmad <khawar.ahmad at cern.ch>wrote:
>> Hi,
>> I am trying to use SWIFT to run sample programs on my test Cloud setup. I
>> am following a tutorial (
>> http://swift-lang.org/tutorials/cloud/tutorial.html).
>> However, the sites.xml file for Part4 is empty and I get the following
>> error from swift
>> "Execution failed:
>> Could not load file sites.xml:
>> com.thoughtworks.xstream.io.StreamException: : input contained no data"
>> Can you tell me what are the settings to run jobs in the Cloud
>> environment? The Cloud is setup using OpenStack.
>> Regards,
>> Khawar
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140115/f5880d5b/attachment.html>
More information about the Swift-user
