[Swift-user] readData is treating line as a single field
Ketan Maheshwari ketan at mcs.anl.gov
Mon Jan 13 14:23:57 CST 2014
I found that the problem was a misplaced space in one of the paths in my
original file used for the run. Removing the space fixed the issue.
While trying to debug/reproduce, I found that readData() works with tabs,
multiple spaces, combination of tabs and spaces and irregular number of
spaces between fields.
On Mon, Jan 13, 2014 at 1:48 PM, Yadu Nand <yadudoc1729 at gmail.com> wrote:
> Hi Ketan,
> Could you give me a sample file and code you're using to test this out ?
> -Yadu
> On Mon, Jan 13, 2014 at 11:46 AM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>> Hi Mike,
>> I am not sure how to introduce a field separator to readData(). I tried
>> adding '|' between header and data fields but seems readData is complaining
>> that file header does not match type and it expected space separated items:
>> File header does not match type. Expected 4 whitespace separated items.
>> Got 5 instead.
>> swiftscript:readData, quadui-multi.swift, line 27
>> On Mon, Jan 13, 2014 at 11:05 AM, Wilde, Michael J. <wilde at mcs.anl.gov>wrote:
>>>  Did you try different field separators? I think in the past Ive used
>>> spaces. Perhaps the readData() code is not sufficiently white-space-aware
>>> yet?
>>>  - Mike
>>> Michael Wilde
>>> Mathematics and Computer Science          Computation Institute
>>> Argonne National Laboratory                    The University of Chicago
>>> *From:* swift-user-bounces at ci.uchicago.edu [
>>> swift-user-bounces at ci.uchicago.edu] on behalf of Ketan Maheshwari [
>>> ketan at mcs.anl.gov]
>>> *Sent:* Monday, January 13, 2014 11:01 AM
>>> *To:* Swift User
>>> *Subject:* [Swift-user] readData is treating line as a single field
>>>   Hi,
>>>  I am trying to use readData() function in Swift to read fields into a
>>> Swift structure but seems it is reading the whole line as a single field.
>>>  Here is my text file for the data:
>>>  $ cat data.txt
>>> Survey_data Strategy_data Field_data quadui_outdir
>>> /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/EMBU/Survey_data_import_fixed.zip
>>> /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/EMBU/Seasonal_strategy_fixed.zip
>>>  /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/EMBU/Field_Overlay_fixed.zip
>>> /home/kcm92/outdir_1
>>> /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/ISHIARA/Survey_data_import_fixed.zip
>>> /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/ISHIARA/Seasonal_strategy_fixed.zip
>>> /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/ISHIARA/Field_Overlay_fixed.zip
>>> /home/kcm92/outdir_2
>>>  I have 4 fields and 2 rows.
>>>  Here is the structure definition:
>>>  type Data{
>>>     string Survey_data;
>>>     string Field_data;
>>>     string Strategy_data;
>>>     string quadui_outdir;
>>>  Here is the Swift loop that I am using to process this data:
>>>  Data d[] = readData(@arg("data"));
>>> /* run quadui */
>>> foreach ditem in d{
>>> tracef("Survey data is: %s", ditem.Survey_data);
>>>  In the output, I get the whole first row of the file instead of the
>>> expected first field.
>>>  Any clues?
>>>  Thanks,
>>> Ketan
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140113/1e6173fa/attachment.html>
More information about the Swift-user mailing list
