[Swift-user] readData is treating line as a single field
Yadu Nand
yadudoc1729 at gmail.com
Mon Jan 13 13:48:43 CST 2014
Hi Ketan,
Could you give me a sample file and code you're using to test this out ?
-Yadu
On Mon, Jan 13, 2014 at 11:46 AM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
> Hi Mike,
> I am not sure how to introduce a field separator to readData(). I tried
> adding '|' between header and data fields but seems readData is complaining
> that file header does not match type and it expected space separated items:
> File header does not match type. Expected 4 whitespace separated items.
> Got 5 instead.
> swiftscript:readData, quadui-multi.swift, line 27
> On Mon, Jan 13, 2014 at 11:05 AM, Wilde, Michael J. <wilde at mcs.anl.gov>wrote:
>> Did you try different field separators? I think in the past Ive used
>> spaces. Perhaps the readData() code is not sufficiently white-space-aware
>> yet?
>> - Mike
>> Michael Wilde
>> Mathematics and Computer Science Computation Institute
>> Argonne National Laboratory The University of Chicago
>> *From:* swift-user-bounces at ci.uchicago.edu [
>> swift-user-bounces at ci.uchicago.edu] on behalf of Ketan Maheshwari [
>> ketan at mcs.anl.gov]
>> *Sent:* Monday, January 13, 2014 11:01 AM
>> *To:* Swift User
>> *Subject:* [Swift-user] readData is treating line as a single field
>> Hi,
>> I am trying to use readData() function in Swift to read fields into a
>> Swift structure but seems it is reading the whole line as a single field.
>> Here is my text file for the data:
>> $ cat data.txt
>> Survey_data Strategy_data Field_data quadui_outdir
>> /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/EMBU/Survey_data_import_fixed.zip
>> /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/EMBU/Seasonal_strategy_fixed.zip
>> /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/EMBU/Field_Overlay_fixed.zip
>> /home/kcm92/outdir_1
>> /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/ISHIARA/Survey_data_import_fixed.zip
>> /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/ISHIARA/Seasonal_strategy_fixed.zip
>> /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/ISHIARA/Field_Overlay_fixed.zip
>> /home/kcm92/outdir_2
>> I have 4 fields and 2 rows.
>> Here is the structure definition:
>> type Data{
>> string Survey_data;
>> string Field_data;
>> string Strategy_data;
>> string quadui_outdir;
>> Here is the Swift loop that I am using to process this data:
>> Data d[] = readData(@arg("data"));
>> /* run quadui */
>> foreach ditem in d{
>> tracef("Survey data is: %s", ditem.Survey_data);
>> In the output, I get the whole first row of the file instead of the
>> expected first field.
>> Any clues?
>> Thanks,
>> Ketan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140113/7f124a8e/attachment.html>
More information about the Swift-user
