[Swift-user] readData is treating line as a single field
Wilde, Michael J. wilde at mcs.anl.gov
Mon Jan 13 11:05:32 CST 2014
Did you try different field separators? I think in the past Ive used spaces. Perhaps the readData() code is not sufficiently white-space-aware yet?
- Mike
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory                    The University of Chicago
From: swift-user-bounces at ci.uchicago.edu [swift-user-bounces at ci.uchicago.edu] on behalf of Ketan Maheshwari [ketan at mcs.anl.gov]
Sent: Monday, January 13, 2014 11:01 AM
To: Swift User
Subject: [Swift-user] readData is treating line as a single field
I am trying to use readData() function in Swift to read fields into a Swift structure but seems it is reading the whole line as a single field.
Here is my text file for the data:
$ cat data.txt
Survey_data Strategy_data Field_data quadui_outdir
/home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/EMBU/Survey_data_import_fixed.zip /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/EMBU/Seasonal_strategy_fixed.zip  /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/EMBU/Field_Overlay_fixed.zip /home/kcm92/outdir_1
/home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/ISHIARA/Survey_data_import_fixed.zip /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/ISHIARA/Seasonal_strategy_fixed.zip /home/kcm92/faceit-pipeline/FIXED_ACE_DOME/ACCESS1/4.5/MID/ISHIARA/Field_Overlay_fixed.zip /home/kcm92/outdir_2
I have 4 fields and 2 rows.
Here is the structure definition:
type Data{
    string Survey_data;
    string Field_data;
    string Strategy_data;
    string quadui_outdir;
Here is the Swift loop that I am using to process this data:
Data d[] = readData(@arg("data"));
/* run quadui */
foreach ditem in d{
tracef("Survey data is: %s", ditem.Survey_data);
In the output, I get the whole first row of the file instead of the expected first field.
Any clues?
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140113/56c48a72/attachment.html>
More information about the Swift-user mailing list
