[Swift-user] Coaster Service Startup Time on OSDC
David Kelly davidkelly at uchicago.edu
Thu Feb 13 12:52:41 CST 2014
Hi Matthew,
Could you please explain a little more about how you're starting the
coaster-service and workers? Are you using the start-coaster-service
script? If you are, could you please send the coaster-service.conf file
you're using? Which version of Swift is this?
There may be some things we can do to speed up the process - just need to
get a better understanding of how things are set up and where the delays
are coming from. Thanks!
David
On Thu, Feb 13, 2014 at 12:23 PM, Matthew Shaxted
<Matthew.Shaxted at som.com>wrote:
> Dear Swift User Group:
> I working with a 60-node cluster running on OSDC now, and when I try to
> start the Swift coaster-service for these nodes, it takes about 30 seconds
> (or more) per node to successfully start.
> This is an issue for me as it limits how often I want to shut down the
> coaster-service - for this 60 node cluster it could take up to 30 min to
> start up again.
> Is this starting coaster behavior normal? Is there anything I can do to
> make the coaster-service start faster?
> Thanks,
> Matthew
> MATTHEW SHAXTED
> SKIDMORE, OWINGS & MERRILL LLP
> 224 South Michigan Ave.
> Chicago, IL 60604
> TEL: 312.360.4368
> FAX: 312.360.4545
> matthew.shaxted at som.com
> [image: cid:image9d6458.png at 2965c709.c87949ac]
> WWW.SOM.COM <http://www.som.com/>
> The information contained in this communication may be confidential, is
> intended only for the use of the recipient(s) named above, and may be
> legally privileged. If the reader of this message is not the intended
> recipient, you are hereby notified that any dissemination, distribution, or
> copying of this communication, or any of its contents, is strictly
> prohibited and may be unlawful. If you have received this communication in
> error, please return it to the sender immediately and delete the original
> message and any copy of it from your computer system. If you have any
> questions concerning this message, please contact the sender.
> [image: cid:image93798a.gif at f078f826.ddd94773]
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140213/d49cdb74/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140213/d49cdb74/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140213/d49cdb74/attachment-0001.png>
More information about the Swift-user mailing list
