[Swift-user] Edison: pbs job starts but Swift unresponsive
Ketan Maheshwari ketan at mcs.anl.gov
Tue Dec 30 12:49:33 CST 2014
Hi Mihael,
It takes about 8-9 minutes after the worker starting (ie. queue showing
running status) that the Swift progress text shows active status. In the
active status, one wave of tasks finishes and the status goes back to
submit state but now no job shows up in the queue.
Attached is a rundir of one such run.
Thanks for any inputs,
Ketan
On Tue, Dec 23, 2014 at 4:37 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Hi Ketan,
> The PBS job having started means that the workers have started. However,
> there are some steps that need to happen between that and the workers
> being able to receive jobs. I'm guessing some of those steps might
> either be failing or they take some time.
> If you could send a log, that might help figure out what's happening.
> Mihael
> On Tue, 2014-12-23 at 15:15 -0600, Ketan Maheshwari wrote:
> > Hi,
> > Trying to run an application on Edison (Cray).
> > I see with qsub that the job has started but on the Swift side, I still
> see
> > status as submitted.
> > This happens with local:pbs coasters with both 0.95 and latest trunk
> using
> > a simple catsn example.
> > Any suggestions?
> > Thanks,
> > Ketan
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141230/4a239b40/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141230/4a239b40/attachment.bin>
More information about the Swift-user mailing list
