[Swift-user] Edison: pbs job starts but Swift unresponsive
Mihael Hategan
hategan at mcs.anl.gov
Tue Dec 23 16:37:45 CST 2014
Hi Ketan,
The PBS job having started means that the workers have started. However,
there are some steps that need to happen between that and the workers
being able to receive jobs. I'm guessing some of those steps might
either be failing or they take some time.
If you could send a log, that might help figure out what's happening.
Mihael
On Tue, 2014-12-23 at 15:15 -0600, Ketan Maheshwari wrote:
> Hi,
> Trying to run an application on Edison (Cray).
> I see with qsub that the job has started but on the Swift side, I still see
> status as submitted.
> This happens with local:pbs coasters with both 0.95 and latest trunk using
> a simple catsn example.
> Any suggestions?
> Thanks,
> Ketan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
