[Swift-user] Block task failed: Connection to worker lost
Mihael Hategan
hategan at mcs.anl.gov
Fri Dec 5 13:18:41 CST 2014
On Fri, 2014-12-05 at 10:37 -0600, Ozik, Jonathan wrote:
> Mihael,
> Thanks. Is there a document that explains the details of each of the
> staging options?
http://swift-lang.org/guides/trunk/userguide/userguide.html#table-staging-methods
> As reference, when I tried to use the wrapper or swift staging or
> omitted the staging specifier I got errors. The direct, local, and
> shared-fs staging didn’t throw errors. For the swift staging I got the
> error:
> Caused by: Could not find a suitable service/provider for host
> midway_debug
Right. For swift staging you need to specify a filesystem type that
swift will use to do the actual copying between the swift side and
wherever the jobs are submitted to. This is the legacy way of dealing
with data in swift.
"Wrapper" you might not want to use. We are still working on the finer
details of that.
Mihael
More information about the Swift-user
