[Swift-user] Swift and allocations
Jonathan Ozik
jozik at uchicago.edu
Tue Aug 12 13:45:52 CDT 2014
Hi Mihael,
Thank you, good to know.
The jobWalltime, should that be thought of as the length of time that each block will stay up? For example, if resources are tight and only a few blocks are started, while the rest of the blocks are waiting for resources to free up, if the first few blocks reach their jobWalltimes, will those be shut down?
Jonathan
On Aug 12, 2014, at 12:37 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Hi Jonathan,
> There is no specific code to attempt to bunch the invocations to fewer
> blocks. Essentially the 382 cores that finish their previous 512 jobs
> first will get the new jobs.
> However, if any of the nodes are left without jobs, they will get shut
> down.
> Mihael
> On Tue, 2014-08-12 at 11:53 -0500, Jonathan Ozik wrote:
>> Hello all,
>> I had a discussion with Yadu and we thought we’d open it up to the
>> list. Suppose that we are throttling the total number of concurrent
>> tasks to 512 (taskThrottle=512) and by specifying that maxJobs=32 and
>> tasksPerWorker=16. If there are a total of 2430 total tasks to run,
>> there will be 2430 - 2048 = 382 tasks left for the last “go
>> around” (assuming that each of the tasks take about the same time to
>> complete). If there are 382 tasks left towards run completion and 512
>> cores (16 for each of the 32 nodes), would the last few jobs, end up
>> spread across the 32 Nodes, effectively holding them and burning your
>> allocation, or would they get pushed to 24 nodes and de-allocating 8
>> nodes?
>> Jonathan
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
