[Swift-user] Newer sites properties
Yadu Nand yadudoc1729 at gmail.com
Fri Aug 8 16:40:33 CDT 2014
Hi Jonathan,
The 0.95 sites properties were updated with the configs that will be
supported on trunk and 0.96. I'm attaching an older userguide which
has the configs for swift-0.95.
​Thanks,
Yadu​
On Fri, Aug 8, 2014 at 2:36 PM, Jonathan Ozik <jozik at uchicago.edu> wrote:
> Is there a place where the newer (0.95+) sites properties are defined? For
> example, jobWalltime, taskWalltime . I couldn’t find them in the user guide
> (http://swift-lang.org/guides/trunk/userguide/userguide.html).
> Thanks!
> Jonathan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140808/ff68315a/attachment.html>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140808/ff68315a/attachment.pdf>
More information about the Swift-user mailing list
