[Swift-user] SWIFT Generates "incompatible" PBS scripts
chen sui baiypwup at hotmail.com
Wed Apr 2 12:28:39 CDT 2014
Hello SWIFT,I have been using SWIFT on two different clusters, it has always been running flawlessly on one of the clusters, but it fails on the second one.
I think I have narrowed down the cause of the problem;
When I have these lines (the 2 lines with stars in the following example) in a generated PBS script,
[begin example]
#PBS -S /bin/bash
#PBS -N B0402-0012360-0
#PBS -m n
(omitted)
export WORKER_LOGGING_LEVEL=NONE   (*)
#PBS -v WORKER_LOGGING_LEVEL  (*)
[end example]
The last two lines is causing the PBS to be incompatible with one of the clusters I'm using. When I submit such a script, I get the following error.
[begin Console output]
[cs900601 at eric2 scripts]$ qsub PBS4684660157119642383.submit
506530.eric2
** Job deleted, insufficient hours (0 < 96) left in allocation null **
[end Console output]
Clearly, for some reason the qsub on this cluster has "forgotten" every "#PBS" directive prior to the "export" line.
The reason seems to be
   1) the cluster I'm using does not support the "-v" switch.
   2) Does not accept PBS script whose "#PBS" lines have been "interrupted" by an non PBS directive (the "export" above).
That means, if I am able to make Swift remove the 2 lines during script generation the problem would go away.
So my question is, is it possible to do this through Swift configurations?
I have searched the configuration files but not seem to find a way to do it. The generated script says in the 1st line it's generated by a Java class "by class: class org.globus.cog.abstraction.impl.scheduler.pbs.PBSExecutor".
Is there a way to check out the source of that "PBSExecutor" class to see what is adding these two lines with asterisks in the generated script and disable it?
Thanks!Tommy Chen
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140403/5468201c/attachment.html>
More information about the Swift-user mailing list
