[Swift-user] Coordination between app calls in foreach loop
Yadu Nand
yadudoc1729 at gmail.com
Fri Sep 20 16:13:26 CDT 2013
Hi Ketan,
I have a test which can confirm the same behavior you are seeing, which I
think is a bug.
For now, I have a tested piece of code which forces the three foreach loops
into sequence:
Hope this helps:
iterate loop_count {
switch (loop_count) {
case 0:
foreach i in [0:3]{
outfileA[i] = A ("astring");
art[i]=i;
case 1:
foreach j in [0:3]{
outfileB[j] = B ("bstring");
default:
tracef("Reached end loop_count:%i \n", loop_count);
} until (loop_count == 2);
-Yadu
On Fri, Sep 20, 2013 at 2:08 PM, Ketan Maheshwari <
ketancmaheshwari at gmail.com> wrote:
> Hi,
> I am working with APS user Hemant Sharma (in CC) on one of his projects.
> Hemant wrote a Swift script which has about three foreach invocations which
> he wants to run one after other.
> In order to achieve this coordination, Hemant is using an int[] in one
> loop which is passed as input to the app call of another loop. He observes
> that the coordination is not maintained and both app calls happen
> simultaneously resulting in application error.
> Here is a quick reproduction I tried and I observe indeed that
> coordination is not happening:
> $ cat dummy.swift
> type file;
> app (file out) A (string in1){
> dummyA in1 stdout=@out;
> app (file out) B (string in1, int[] _art){
> dummyB in1 stdout=@out;
> file outfileA[]<simple_mapper; location="outdir",
> prefix="a.",suffix=".out">;
> file outfileB[]<simple_mapper; location="outdir",
> prefix="b.",suffix=".out">;
> int art[];
> foreach i in [0:3]{
> art[i]=i;
> foreach j in [0:3]{
> outfileB[j] = B ("bstring", art);
> Since the art array is wholly required in app B, one would expect the
> first foreach to finish befor the call to B gets invoked. This is not
> happening in my simple test where I ask the executable called by A to sleep
> for 5 sec and that called by B to print timestamp and quit.
> I see in the resulting files that the timestamps in B precede those in A.
> This looks like a bug to me. Swift is 0.94 swift-r7091 cog-r3789.
> Thanks,
> Ketan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20130920/92d95537/attachment.html>
More information about the Swift-user
