[Swift-user] Coordination between app calls in foreach loop
Ketan Maheshwari
ketancmaheshwari at gmail.com
Fri Sep 20 14:08:38 CDT 2013
I am working with APS user Hemant Sharma (in CC) on one of his projects.
Hemant wrote a Swift script which has about three foreach invocations which
he wants to run one after other.
In order to achieve this coordination, Hemant is using an int[] in one loop
which is passed as input to the app call of another loop. He observes that
the coordination is not maintained and both app calls happen simultaneously
resulting in application error.
Here is a quick reproduction I tried and I observe indeed that coordination
is not happening:
$ cat dummy.swift
type file;
app (file out) A (string in1){
dummyA in1 stdout=@out;
app (file out) B (string in1, int[] _art){
dummyB in1 stdout=@out;
file outfileA[]<simple_mapper; location="outdir",
prefix="a.",suffix=".out">;
file outfileB[]<simple_mapper; location="outdir",
prefix="b.",suffix=".out">;
int art[];
foreach i in [0:3]{
outfileA[i] = A ("astring");
art[i]=i;
foreach j in [0:3]{
outfileB[j] = B ("bstring", art);
Since the art array is wholly required in app B, one would expect the first
foreach to finish befor the call to B gets invoked. This is not happening
in my simple test where I ask the executable called by A to sleep for 5 sec
and that called by B to print timestamp and quit.
I see in the resulting files that the timestamps in B precede those in A.
This looks like a bug to me. Swift is 0.94 swift-r7091 cog-r3789.
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20130920/85324581/attachment.html>
More information about the Swift-user
