[Swift-user] Need help with Integer cannot be cast to String
Andrew Shewmaker
agshew at gmail.com
Mon Jul 15 13:44:31 CDT 2013
On Mon, Jul 15, 2013 at 11:44 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Hi Andrew,
>> I am still a bit puzzled because I seem to need to declare arrays
>> even
>> when I only have one .NVT and .NEV file.
> Yes, thats the convention for filesys_mapper and simple_mapper.
> To map just one file, use single_file_mapper.
Ah, right. I forgot I read that in the manual.
>> By the way, I saw that a gui monitor exists in the source code. I
>> tried it out and liked it. Are there any future plans for it?
> Which one did you try - -monitor (X GUI) or -tui (textual curse GUI)? Our plan is to merge these and convert/extend the unified monitoring mechanism to create a web-browser-based interface.
> We'd welcome your collaboration if you'd like to work on this project.
I tried both of those. I especially appreciated the Apps view and also
the Completed/Started column in Ben's view in the TUI. The X monitor
provided a nice compact overview. I also dug into the source and tried
out the Java Swing gui. I was surprised how much I liked the Gantt
chart.
The customer I'm investigating Swift for would really appreciate
something like the web or Java swing interface. If they like this demo
I've just finished, then I'd like to collaborate with you on
monitoring.
I'll know more tomorrow.
Andrew Shewmaker
More information about the Swift-user
