[Swift-user] Need help with Integer cannot be cast to String
Andrew Shewmaker agshew at gmail.com
Fri Jul 12 17:49:35 CDT 2013
Sorry, I should have said that I was running:
./usecase1.sh -filter=1 -clean=1
I'm using Mac OS X Snow Leopard and swift 0.94 ... with an updated
script _swiftwrap from my previous bug report. I also tried it with a
version of Swift I built from the repo, but I should have tried it on Linux too.
java version "1.6.0_45"
Java(TM) SE Runtime Environment (build 1.6.0_45-b06-451-11M4406)
Java HotSpot(TM) 64-Bit Server VM (build 20.45-b01-451, mixed mode
Hmmm ... I thought I had updated Java already.
Thanks for your help, Michael!
Did it error out on one of the processDataSet() calls for you?
-Andrew
On Fri, Jul 12, 2013 at 4:16 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Andrew, sorry - I see that I need to uncomment the offending statement.
> I can reproduce the error now and will look into it.
> - Mike
>> From: "Michael Wilde" <wilde at mcs.anl.gov>
>> To: "Andrew Shewmaker" <agshew at gmail.com>
>> Cc: swift-user at ci.uchicago.edu
>> Sent: Friday, July 12, 2013 5:11:18 PM
>> Subject: Re: [Swift-user] Need help with Integer cannot be cast to String
>> I should also note that I was running under this Java:
>> swift$ java -version
>> java version "1.7.0_17"
>> Java(TM) SE Runtime Environment (build 1.7.0_17-b02)
>> Java HotSpot(TM) 64-Bit Server VM (build 23.7-b01, mixed mode)
>> swift$
>> - Mike
>> > Sent: Friday, July 12, 2013 4:48:06 PM
>> > String
>> > Hi Andrew,
>> > I was able to run your test case under Swift 0.94 on an Intel Linux
>> > host, and it ran to completion, doing 30 app() tasks without
>> > failure. (It encountered a small problem in cleanup, but thats a
>> > separate minor issue):
>> > Final status: Fri, 12 Jul 2013 21:35:45 +0000  Finished
>> > successfully:30
>> > Failed to clean
>> > file://localhost/_concurrent/waitnst-60fff1d4-b1af-4de8-80b6-234512833f01-4-0
>> > Starting cleanups
>> > Swift finished with no errors
>> > swift$ which swift
>> > /software/swift-0.94-all/bin/swift
>> > swift$ swift -version
>> > Swift 0.94 swift-r6414 (swift modified locally) cog-r3648
>> > What version of Swift were you running, on what platform? I vaguely
>> > recall a similar error, and wonder if you are running an older
>> > Swift.
>> > Can you send us the .log file for the failing run?
>> > Also, what version of Java were you using?
>> > Below is the directory this created for me.
>> > Thanks,
>> > - Mike
>> > swift$ cd firstdataset/
>> > swift$ ls -lt
>> > total 2944
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 8.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 8.1.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 8.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 18.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 18.1.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 18.4.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 12.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 12.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 12.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 28.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 28.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 28.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 29.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 29.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 29.2.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 0.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 0.1.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 0.2.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 1.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 23.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 1.1.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 1.4.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 3.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 23.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 3.1.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 3.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 23.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 13.2.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 13.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 13.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 9.1.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 9.4.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 9.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 17.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 27.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 21.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 21.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 21.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 27.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 27.2.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 6.4.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 6.2.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 17.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 6.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 17.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 20.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 20.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 20.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 10.2.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 10.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 10.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 4.1.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 4.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 19.2.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 4.4.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 14.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 19.1.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 19.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 14.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 14.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 26.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 26.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 26.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 22.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 22.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 22.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 11.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 11.2.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 11.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 24.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 24.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 24.2.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 5.4.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 15.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 5.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 15.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 16.1.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 16.4.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 2.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 25.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 16.2.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 5.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 7.1.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 25.1.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 7.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 25.2.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 2.1.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 7.4.T
>> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 15.2.T
>> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 2.2.T
>> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 9.NSE
>> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 8.NSE
>> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 7.NSE
>> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 6.NSE
>> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 5.NSE
>> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 4.NSE
>> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 3.NSE
>> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 29.NTT
>> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 28.NTT
>> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 27.NTT
>> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 26.NTT
>> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 25.NTT
>> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 24.NTT
>> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 23.NTT
>> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 22.NTT
>> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 21.NTT
>> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 20.NTT
>> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 2.NSE
>> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 19.NST
>> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 18.NST
>> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 17.NST
>> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 16.NST
>> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 15.NST
>> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 14.NST
>> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 13.NST
>> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 12.NST
>> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 11.NST
>> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 10.NST
>> > -rw-r--r-- 1 wilde wilde  44 Jul 12 16:34 1.NVT
>> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 1.NSE
>> > -rw-r--r-- 1 wilde wilde  28 Jul 12 16:34 1.NEV
>> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 0.NSE
>> > swift$
>> > > From: "Andrew Shewmaker" <agshew at gmail.com>
>> > > To: swift-user at ci.uchicago.edu
>> > > Sent: Friday, July 12, 2013 3:18:36 PM
>> > > Subject: [Swift-user] Need help with Integer cannot be cast to
>> > > String
>> > > Hi,
>> > > I'm learning how use Swift, and I'm trying to understand what I'm
>> > > doing
>> > > wrong that's causing this failure:
>> > > java.lang.ClassCastException: java.lang.Integer cannot be cast to
>> > > java.lang.String
>> > > on line 78 of the attached usecase1.swift
>> > > I don't think I'm trying to use an Integer in the line that's
>> > > mentioned.
>> > > Any help would be appreciated!
>> > > Thanks,
>> > > Andrew Shewmaker
>> > > _______________________________________________
>> > > Swift-user mailing list
>> > > Swift-user at ci.uchicago.edu
>> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Andrew Shewmaker
More information about the Swift-user mailing list
