[Swift-user] Need help with Integer cannot be cast to String
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Jul 12 17:16:01 CDT 2013
Andrew, sorry - I see that I need to uncomment the offending statement.
I can reproduce the error now and will look into it.
- Mike
----- Original Message -----
> From: "Michael Wilde" <wilde at mcs.anl.gov>
> To: "Andrew Shewmaker" <agshew at gmail.com>
> Cc: swift-user at ci.uchicago.edu
> Sent: Friday, July 12, 2013 5:11:18 PM
> Subject: Re: [Swift-user] Need help with Integer cannot be cast to String
> I should also note that I was running under this Java:
> swift$ java -version
> java version "1.7.0_17"
> Java(TM) SE Runtime Environment (build 1.7.0_17-b02)
> Java HotSpot(TM) 64-Bit Server VM (build 23.7-b01, mixed mode)
> swift$
> - Mike
> > Sent: Friday, July 12, 2013 4:48:06 PM
> > String
> > Hi Andrew,
> > I was able to run your test case under Swift 0.94 on an Intel Linux
> > host, and it ran to completion, doing 30 app() tasks without
> > failure. (It encountered a small problem in cleanup, but thats a
> > separate minor issue):
> > Final status: Fri, 12 Jul 2013 21:35:45 +0000  Finished
> > successfully:30
> > Failed to clean
> > file://localhost/_concurrent/waitnst-60fff1d4-b1af-4de8-80b6-234512833f01-4-0
> > Starting cleanups
> > Swift finished with no errors
> > swift$ which swift
> > /software/swift-0.94-all/bin/swift
> > swift$ swift -version
> > Swift 0.94 swift-r6414 (swift modified locally) cog-r3648
> > What version of Swift were you running, on what platform? I vaguely
> > recall a similar error, and wonder if you are running an older
> > Swift.
> > Can you send us the .log file for the failing run?
> > Also, what version of Java were you using?
> > Below is the directory this created for me.
> > Thanks,
> > - Mike
> > swift$ cd firstdataset/
> > swift$ ls -lt
> > total 2944
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 8.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 8.1.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 8.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 18.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 18.1.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 18.4.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 12.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 12.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 12.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 28.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 28.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 28.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 29.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 29.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 29.2.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 0.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 0.1.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 0.2.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 1.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 23.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 1.1.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 1.4.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 3.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 23.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 3.1.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 3.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 23.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 13.2.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 13.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 13.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 9.1.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 9.4.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 9.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 17.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 27.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 21.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 21.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 21.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 27.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 27.2.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 6.4.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 6.2.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:35 17.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 6.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 17.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 20.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 20.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:35 20.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 10.2.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 10.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 10.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 4.1.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 4.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 19.2.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 4.4.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 14.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 19.1.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 19.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 14.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 14.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 26.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 26.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 26.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 22.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 22.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 22.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 11.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 11.2.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 11.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 24.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 24.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 24.2.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 5.4.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 15.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 5.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 15.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 16.1.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 16.4.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 2.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 25.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 16.2.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 5.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 7.1.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 25.1.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 7.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 25.2.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 2.1.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 7.4.T
> > -rw-rw-r-- 1 wilde wilde  40 Jul 12 16:34 15.2.T
> > -rw-rw-r-- 1 wilde wilde   0 Jul 12 16:34 2.2.T
> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 9.NSE
> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 8.NSE
> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 7.NSE
> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 6.NSE
> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 5.NSE
> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 4.NSE
> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 3.NSE
> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 29.NTT
> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 28.NTT
> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 27.NTT
> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 26.NTT
> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 25.NTT
> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 24.NTT
> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 23.NTT
> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 22.NTT
> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 21.NTT
> > -rw-r--r-- 1 wilde wilde 160 Jul 12 16:34 20.NTT
> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 2.NSE
> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 19.NST
> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 18.NST
> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 17.NST
> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 16.NST
> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 15.NST
> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 14.NST
> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 13.NST
> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 12.NST
> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 11.NST
> > -rw-r--r-- 1 wilde wilde  80 Jul 12 16:34 10.NST
> > -rw-r--r-- 1 wilde wilde  44 Jul 12 16:34 1.NVT
> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 1.NSE
> > -rw-r--r-- 1 wilde wilde  28 Jul 12 16:34 1.NEV
> > -rw-r--r-- 1 wilde wilde  40 Jul 12 16:34 0.NSE
> > swift$
> > > From: "Andrew Shewmaker" <agshew at gmail.com>
> > > To: swift-user at ci.uchicago.edu
> > > Sent: Friday, July 12, 2013 3:18:36 PM
> > > Subject: [Swift-user] Need help with Integer cannot be cast to
> > > String
> > > Hi,
> > > I'm learning how use Swift, and I'm trying to understand what I'm
> > > doing
> > > wrong that's causing this failure:
> > > java.lang.ClassCastException: java.lang.Integer cannot be cast to
> > > java.lang.String
> > > on line 78 of the attached usecase1.swift
> > > I don't think I'm trying to use an Integer in the line that's
> > > mentioned.
> > > Any help would be appreciated!
> > > Thanks,
> > > Andrew Shewmaker
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
