[Swift-user] running swift k on multiple instances on EC2, using coaster-service
David Kelly davidk at ci.uchicago.edu
Wed Oct 24 10:28:50 CDT 2012
Iman,
There is some documentation on how to use the start-coaster-service script at http://www.ci.uchicago.edu/swift/guides/release-0.93/siteguide/siteguide.html#_bag_of_workstations. You should be able to follow the "bag of workstations" configuration example once you have started your EC2 instance. That may help to simplify things for you a bit. Please let me know if you have any questions or issues with this.
David
----- Original Message -----
> From: "Iman Sadooghi" <isadoogh at iit.edu>
> To: swift-user at ci.uchicago.edu
> Sent: Tuesday, October 23, 2012 5:46:57 PM
> Subject: [Swift-user] running swift k on multiple instances on EC2, using coaster-service
> Hi everyone
> I am trying to run a Montage application workflow with swift on
> multiple instances of AMAZON EC2.
> So far I was able to set up a cluster, and a PVFS files system shared
> among the nodes ( using FUSE. so I will have POSIX interface on my
> swift work directory ).
> I have tried running a simple hello.swift example on multiple nodes
> with the coaster. the working directory is the shared folder
> (supported by PVFS).
> when I run the code using my own tc.data and sites.xml, this will
> happen:
> (my command) ubuntu at ip-10-244-4-101:~/coaster$ swift -tc.file tc.data
> -sites.file sites.xml ~/swift-0.93/examples/swift/tutorial/hello.swift
> (results:)
> Swift 0.93 swift-r5483 cog-r3339
> RunID: 20121023-2200-4d3knr72
> Progress: time: Tue, 23 Oct 2012 22:00:50 +0000
> Find: http://10.244.4.101:1213
> Find: keepalive(120), reconnect - http://10.244.4.101:1213
> Passive queue processor initialized. Callback URI is
> http://10.244.4.101:1212
> Progress: time: Tue, 23 Oct 2012 22:01:20 +0000 Submitted:1
> Progress: time: Tue, 23 Oct 2012 22:01:50 +0000 Submitted:1
> Progress: time: Tue, 23 Oct 2012 22:02:20 +0000 Submitted:1
> Progress: time: Tue, 23 Oct 2012 22:02:50 +0000 Submitted:1
> Progress: time: Tue, 23 Oct 2012 22:03:20 +0000 Submitted:1
> Progress: time: Tue, 23 Oct 2012 22:03:50 +0000 Submitted:1
> Progress: time: Tue, 23 Oct 2012 22:04:20 +0000 Submitted:1
> and it keeps doing this forever meaning that there is no answer from
> worker nodes!
> as I checked on worker nodes, the working files are created on the
> shared folder, and when i check the running applications, there is a
> java application running. but nothing happens.
> I have also attached the log file of my hello.swift running in case
> you need to take a look at it.
> should I consider using pbs, or condor,... I have no idea about how
> they work though.
> I appreciate if anyone can help me with it. Thank you so much.
> Best, --
> Iman Sadooghi
> Illinois Institute of Technology (IIT)
> Data-Intensive Distributed Systems Laboratory
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
