[Swift-user] Running coasters on a bag of workstations
Carsen Berger
clberger at uchicago.edu
Sat May 19 20:24:01 CDT 2012
Thanks everyone for the replies!
David, you were right: I just needed to include the -config cf option when
running Swift.
Best,
Carsen
On Sat, May 19, 2012 at 6:00 PM, David Kelly <davidk at ci.uchicago.edu> wrote:
> Carsen,
> When you set WORKER_LOCATION to a non-shared directory, you need to enable
> coaster provider staging. To do this, add a line to your
> coaster-service.conf that says:
> export SHARED_FILESYSTEM=no
> When you run start-coaster-service the next time, a file called 'cf' will
> be created. Then run swift with something like this:
> swift -sites.file sites.xml -tc.file tc.data -config cf myscript.swift
> I think this should do the trick, but please let me know if you run into
> anything else. I'll try to update the documentation to make this more clear.
> Regards,
> David
> > From: "Carsen Berger" <clberger at uchicago.edu>
> > To: swift-user at ci.uchicago.edu
> > Sent: Saturday, May 19, 2012 4:17:03 PM
> > Subject: [Swift-user] Running coasters on a bag of workstations
> > Hi all,
> > I'm trying to run coasters on a collection of commodity machines and
> > I'm running into some issues. The machines all share a common /home
> > directory on a NFS file system, so to give the coaster workers local
> > storage, I decided to set the WORKER_LOCATION directory to the local
> > /var/tmp on each machine.
> > Running start-coaster-service installs worker.pl in /var/tmp just
> > fine, but then when we try to run a swift script it spits out a slew
> > of "No such file or directory" errors for all the files that the
> > worker is supposed to create. It seems as if coasters cannot write to
> > /var/tmp for whatever reason. Has anyone encountered a problem like
> > this before?
> > Note that setting WORKER_LOCATION to a directory in /home circumvents
> > this problem, but that solution won't work because we need a directory
> > that is local to each machine.
> > Thank you,
> > Carsen Berger
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120519/74f9f5ba/attachment.html>
More information about the Swift-user
