[Swift-user] Running coasters on a bag of workstations
Ketan
ketancmaheshwari at gmail.com
Sat May 19 17:51:46 CDT 2012
Is it possible /tmp is mounted on /tmp and not /var/tmp .. just a quick guess.
On May 19, 2012, at 5:17 PM, Carsen Berger wrote:
> Hi all,
> I'm trying to run coasters on a collection of commodity machines and I'm running into some issues. The machines all share a common /home directory on a NFS file system, so to give the coaster workers local storage, I decided to set the WORKER_LOCATION directory to the local /var/tmp on each machine.
> Running start-coaster-service installs worker.pl in /var/tmp just fine, but then when we try to run a swift script it spits out a slew of "No such file or directory" errors for all the files that the worker is supposed to create. It seems as if coasters cannot write to /var/tmp for whatever reason. Has anyone encountered a problem like this before?
> Note that setting WORKER_LOCATION to a directory in /home circumvents this problem, but that solution won't work because we need a directory that is local to each machine.
> Thank you,
> Carsen Berger
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120519/43580f15/attachment.html>
More information about the Swift-user
