[Swift-user] swift build fail
Ketan Maheshwari ketancmaheshwari at gmail.com
Fri May 4 09:40:28 CDT 2012
ahh! javac is missing. It's got only jre.
On Fri, May 4, 2012 at 10:33 AM, Ketan Maheshwari <
ketancmaheshwari at gmail.com> wrote:
> I am trying to build Swift from trunk on a cluster head node which seems
> to be failing.
> Here is more info:
> cat /etc/redhat-release
> Red Hat Enterprise Linux AS release 4 (Nahant Update 9)
> $ which java
> /usr/local/jre1.6.0_16/bin/java
> $ java -version
> java version "1.6.0_16"
> Java(TM) SE Runtime Environment (build 1.6.0_16-b01)
> Java HotSpot(TM) Server VM (build 14.2-b01, mixed mode)
> $ which ant
> /usr/bin/ant
> $ ant -version
> Apache Ant version 1.6.5 compiled on August 14 2006
> Attached is the ant redist out/err.
> Any idea what is happening?
> Regards,
> Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120504/a3b16dd0/attachment.html>
More information about the Swift-user mailing list
