[Swift-user] swift build fail
Ketan Maheshwari ketancmaheshwari at gmail.com
Fri May 4 09:33:39 CDT 2012
I am trying to build Swift from trunk on a cluster head node which seems to
be failing.
Here is more info:
cat /etc/redhat-release
Red Hat Enterprise Linux AS release 4 (Nahant Update 9)
$ which java
/usr/local/jre1.6.0_16/bin/java
$ java -version
java version "1.6.0_16"
Java(TM) SE Runtime Environment (build 1.6.0_16-b01)
Java HotSpot(TM) Server VM (build 14.2-b01, mixed mode)
$ which ant
/usr/bin/ant
$ ant -version
Apache Ant version 1.6.5 compiled on August 14 2006
Attached is the ant redist out/err.
Any idea what is happening?
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120504/46c09e6a/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120504/46c09e6a/attachment.obj>
More information about the Swift-user mailing list
