[Swift-user] Throttling within Swift
Lorenzo Pesce lpesce at uchicago.edu
Mon Jun 11 15:50:46 CDT 2012
So, if I want to run 24 jobs per node on a 24 core node and use 100 nodes, I set it to 24?
On Jun 6, 2012, at 5:29 PM, Michael Wilde wrote:
> Scott, its best to adjust the throttle using the sites file. Use these two xml elements in your <pool> element:
>    <profile namespace="karajan" key="jobThrottle">.63</profile>
>    <profile namespace="karajan" key="initialScore">10000</profile>
> Always set initialScore to 10000.
> Set the actual throttle by setting jobThrottle to (N-1)/100 to run N jobs at a time.
> So for N=2,4,8,16 set jobThrottle to .01, .03, .07, and .15
> Thats admittedly rather arcane, but works that way for historical reasons. We hope to simplify this in the future.
> - Mike
>> From: "Scott Krieder" <skrieder at iit.edu>
>> To: swift-user at ci.uchicago.edu
>> Sent: Wednesday, June 6, 2012 5:07:03 PM
>> Subject: [Swift-user] Throttling within Swift
>> Quick question about throttling within Swift:
>> I have a swift script that launches 64 binary files in parallel within
>> a foreach loop.
>> I would like Swift to throttle so that there are only 2 binaries
>> running at any given time. Then I would like to change the throttle
>> for 4, 8, and 16.
>> I found several different layers at which I can change the throttle.
>> For the above configuration should I change the throttle in my
>> sites.xml or do I need to update the swift.properties file?
>> Thank you,
>> Scott
>> Scott Krieder
>> DataSys Laboratory
>> Illinois Institute of Technology
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
More information about the Swift-user mailing list
