[Swift-user] Throttling within Swift
Scott Krieder skrieder at iit.edu
Wed Jun 6 17:07:03 CDT 2012
Quick question about throttling within Swift:
I have a swift script that launches 64 binary files in parallel within a
foreach loop.
I would like Swift to throttle so that there are only 2 binaries running at
any given time. Then I would like to change the throttle for 4, 8, and 16.
I found several different layers at which I can change the throttle. For
the above configuration should I change the throttle in my sites.xml or do
I need to update the swift.properties file?
Thank you,
Scott
Scott Krieder
DataSys Laboratory
Illinois Institute of Technology
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120606/0b76357e/attachment.html>
More information about the Swift-user mailing list
