[Swift-user] Swift temporary files / logfiles
Ketan Maheshwari
ketancmaheshwari at gmail.com
Mon Jan 30 14:06:48 CST 2012
I haven't tested but you should be able to disable logs by putting the log
level to OFF in the log4j.properties file.
On Mon, Jan 30, 2012 at 1:50 PM, Emalayan Vairavanathan <
svemalayan at yahoo.com> wrote:
> Hi Ketan,
> Thank you very much. By the way how I can tune log4j.properties /
> disabling log4j ? (Should I disable it via config file ?)
> Thank you
> Emalayan
> *From:* Ketan Maheshwari <ketancmaheshwari at gmail.com>
> *To:* Emalayan Vairavanathan <svemalayan at yahoo.com>
> *Cc:* swift user <swift-user at ci.uchicago.edu>
> *Sent:* Sunday, 29 January 2012 7:57 AM
> *Subject:* Re: [Swift-user] Swift temporary files / logfiles
> Emalayan,
> Swift uses log4j for logging. You should be able to tune the
> log4j.properties to decrease the amount of logs produced. Alternatively,
> you could completely disable log4j from sources.
> Regards,
> Ketan
> On Fri, Jan 27, 2012 at 12:24 AM, Emalayan Vairavanathan <
> Dear All,
> When I run a application with Swift, I can see some temporary files (log
> files and other intermediate files ) are being created inside working
> directory. Is there any way to switch off / reduce these IO operations
> during performance runs ?
> Thank you
> Emalayan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120130/139f1bf2/attachment.html>
More information about the Swift-user
