[Swift-user] Swift temporary files / logfiles
Emalayan Vairavanathan svemalayan at yahoo.com
Mon Jan 30 13:50:39 CST 2012
Hi Ketan,
Thank you very much. By the way how I can tune log4j.properties / disabling log4j ? (Should I disable it via config file ?)
Thank you
Emalayan
 From: Ketan Maheshwari <ketancmaheshwari at gmail.com>
To: Emalayan Vairavanathan <svemalayan at yahoo.com>
Cc: swift user <swift-user at ci.uchicago.edu>
Sent: Sunday, 29 January 2012 7:57 AM
Subject: Re: [Swift-user] Swift temporary files / logfiles
Emalayan,
Swift uses log4j for logging. You should be able to tune the log4j.properties to decrease the amount of logs produced. Alternatively, you could completely disable log4j from sources.
Ketan
On Fri, Jan 27, 2012 at 12:24 AM, Emalayan Vairavanathan <svemalayan at yahoo.com> wrote:
Dear All,
>When I run a application with Swift, I can see some temporary files (log files and other intermediate files ) are being created inside working directory. Is there any way to switch off / reduce these IO operations during performance runs ?
>Thank you
>Emalayan
>_______________________________________________
>Swift-user mailing list
>Swift-user at ci.uchicago.edu
>https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120130/73fc9db8/attachment.html>
More information about the Swift-user mailing list
