[Swift-user] Montage+Swift+Coasters
Emalayan Vairavanathan svemalayan at yahoo.com
Mon Jan 30 13:53:33 CST 2012
Hi Jon, I added mBackground to tc file. But I am still getting the same error.
To answer your questions: Yes I am using only the local machine for now (No workers are started in remote nodes). By the way how we can debug the problem ? Do you think whether having a Skpye session is a good idea ?
Thank you
Emalayan
To: Emalayan Vairavanathan <svemalayan at yahoo.com>
Cc: swift user <swift-user at ci.uchicago.edu>
Sent: Tuesday, 24 January 2012 1:11 PM
Subject: Re: [Swift-user] Montage+Swift+Coasters
Ok.  Try adding it to your tc.  You are only using the local machine correct?  You aren't using some remote cluster are you?
On Jan 24, 2012, at 2:41 PM, Jonathan Monette wrote:
> Error code 127 means that the command wasn't found.
 This line was in the log
> stderr.txt: /bin/sh: mBackground: command not found
> So….do you have all the Montage binaries in your path?  What happens when you say mBackground in the terminal?
> On Jan 24, 2012, at 1:37 PM, Emalayan Vairavanathan wrote:
>> <SwiftMontage-20120124-1127-9a0xujy4.log.gz>
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120130/66df1a7a/attachment.html>
More information about the Swift-user mailing list
