[Swift-user] Montage+Swift+Coasters
Jonathan Monette jonmon at mcs.anl.gov
Tue Jan 24 15:11:15 CST 2012
Ok.  Try adding it to your tc.  You are only using the local machine correct?  You aren't using some remote cluster are you?
On Jan 24, 2012, at 2:41 PM, Jonathan Monette wrote:
> Error code 127 means that the command wasn't found.  This line was in the log
> stderr.txt: /bin/sh: mBackground: command not found
> So….do you have all the Montage binaries in your path?  What happens when you say mBackground in the terminal?
> On Jan 24, 2012, at 1:37 PM, Emalayan Vairavanathan wrote:
>> <SwiftMontage-20120124-1127-9a0xujy4.log.gz>
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
