[Swift-user] surveyor
Jonathan Monette
jonmon at mcs.anl.gov
Wed Jan 25 13:24:39 CST 2012
I tried typing in my password. The prompt just showed back up. That was a second run that was copied. I will retry again though.
On Jan 25, 2012, at 1:22 PM, Mihael Hategan wrote:
> On Wed, 2012-01-25 at 13:19 -0600, Jonathan Monette wrote:
>> Correct. I am logged into communicado and trying to have swift execute using surveyor.
> Btw, those weird characters are there because Java (at least 1.4 and
> lower) did not have a console password masking mechanism. You should
> just type the password, unless there's something else wrong.
> In the mean time I'll check to see if newer versions of Java have a more
> reasonable solution to the problem.
>> On Jan 25, 2012, at 1:14 PM, Mihael Hategan wrote:
>>> On Wed, 2012-01-25 at 10:22 -0600, Jonathan Monette wrote:
>>>> interactive did not seem to work either. This time this is what I got before I killed it.
>>> Seems to be working to some extent :)
>>> I gather you are not running this on a local machine (something that has
>>> the keyboard you are typing on attached to it)?
>>>> Swift trunk swift-r5520 (swift modified locally) cog-r3354
>>>> RunID: 20120125-1013-3iuuhmu7
>>>> Progress: time: Wed, 25 Jan 2012 10:13:18 -0600
>>>> [null] )
>>>> [null] /
>>>> [null] -
>>>> [null] )
>>>> [null] ,/1579>
>>>> Progress: time: Wed, 25 Jan 2012 10:13:26 -0600 Initializing site shared directory:1
>>>> [null] 2
>>>> [null]
>>>> [null] !
>>>> [null]
More information about the Swift-user
