[Swift-user] surveyor
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Jan 25 13:22:39 CST 2012
On Wed, 2012-01-25 at 13:19 -0600, Jonathan Monette wrote:
> Correct.  I am logged into communicado and trying to have swift execute using surveyor.
Btw, those weird characters are there because Java (at least 1.4 and
lower) did not have a console password masking mechanism. You should
just type the password, unless there's something else wrong.
In the mean time I'll check to see if newer versions of Java have a more
reasonable solution to the problem.
> On Jan 25, 2012, at 1:14 PM, Mihael Hategan wrote:
> > On Wed, 2012-01-25 at 10:22 -0600, Jonathan Monette wrote:
> >> interactive did not seem to work either.  This time this is what I got before I killed it.
> > Seems to be working to some extent :)
> > I gather you are not running this on a local machine (something that has
> > the keyboard you are typing on attached to it)?
> >> Swift trunk swift-r5520 (swift modified locally) cog-r3354
> >> RunID: 20120125-1013-3iuuhmu7
> >> Progress:  time: Wed, 25 Jan 2012 10:13:18 -0600
> >> [null] )
> >> [null] /
> >> [null] -
> >> [null] )
> >> [null] ,/1579>
> >> Progress:  time: Wed, 25 Jan 2012 10:13:26 -0600  Initializing site shared directory:1
> >> [null] 2
> >> [null]
> >> [null] !
> >> [null]
More information about the Swift-user
