[Swift-user] surveyor
Mihael Hategan hategan at mcs.anl.gov
Wed Jan 25 00:04:47 CST 2012
Use "interactive" instead of "password".
Mihael
On Tue, 2012-01-24 at 18:17 -0600, Jonathan Monette wrote:
> That does not seem to work.  It never asks me for a password.  Below is the output from the terminal.  After the "[null]" characters are just cycling really fast.  If I type my OTP there it just starts over, as you can see the repeated attempts before the exception.
> [jonmon at communicado: ~/Workspace/Swift/surveyor]$ swift -tc.file tc.data -sites.file sites.xml echo.swift
> Swift trunk swift-r5520 (swift modified locally) cog-r3354
> RunID: 20120124-1813-0xh284fa
> Progress:  time: Tue, 24 Jan 2012 18:13:48 -0600  Initializing:1
>  [jonmon]
>  [null]
> Progress:  time: Tue, 24 Jan 2012 18:13:52 -0600  Initializing site shared directory:1
>  [jonmon]
>  [null]
> Progress:  time: Tue, 24 Jan 2012 18:14:18 -0600  Initializing site shared directory:1
> Progress:  time: Tue, 24 Jan 2012 18:14:20 -0600  Initializing site shared directory:1
>  [jonmon]
>  [null]
> EXCEPTION Could not initialize shared directory on surveyor
> Caused by: null
> Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: org.globus.cog.abstraction.impl.file.FileResourceException: Error while communicating with the SSH server on surveyor.alcf.anl.gov:22
> Caused by: org.globus.cog.abstraction.impl.file.FileResourceException: Error while communicating with the SSH server on surveyor.alcf.anl.gov:22
> Caused by: org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException: Password Authentication failed
> Progress:  time: Tue, 24 Jan 2012 18:14:35 -0600  Failed:1
> Execution failed:
> On Jan 24, 2012, at 6:04 PM, Michael Wilde wrote:
> > Jon, try configuring auth.defaults as you would for a password login, but dont specify a password. Swift should then prompt you for one (with a text prompt, assuming you are running Swift in a non-X setting).  E.g.:
> > login1.pads.ci.uchicago.edu.type=password
> > login1.pads.ci.uchicago.edu.username=wilde
> > I dont know if the ssh provider will maintain a connection so that you only need to provide the OTP once. That might be an issue, if not.
> > - Mike
> > ----- Original Message -----
> >> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> >> To: "swift user" <swift-user at ci.uchicago.edu>
> >> Sent: Tuesday, January 24, 2012 5:32:26 PM
> >> Subject: [Swift-user] surveyor
> >> Hello,
> >> I am trying to run on survey from communicado. Below are the config
> >> files. What other options are there for auth.defaults. I do not have
> >> an ssh key set up on surveyor so I can't say
> >> surveyor.alcf.anl.gov.type=key. The only other way to access surveyor
> >> is with OTP. Since I am using surveyor as a stepping stone to
> >> intrepid(which only has OTP) how do I specify to Swift to use OTP in
> >> auth.defaults. I was trying to use the new ssh-cl provider but that is
> >> only for execution. Swift complains about not being able to create the
> >> share directory so I assumed I couldn't say <filesystem="local"/> so I
> >> have been trying to change it to ssh.
> >> sites.xml
> >> <config>
> >> <pool handle="surveyor">
> >> <execution provider="coaster" jobmanager="ssh-cl:cobalt"
> >> url="surveyor.alcf.anl.gov" />
> >> <filesystem provider="ssh" url="surveyor.alcf.anl.gov" />
> >> <!-- <profile namespace="globus"
> >> key="internalHostname">172.17.3.13</profile> -->
> >> <profile namespace="globus" key="project">MTCScienceApps</profile>
> >> <profile namespace="globus" key="queue">short</profile>
> >> <profile namespace="globus" key="kernelprofile">zeptoos</profile>
> >> <profile namespace="globus" key="alcfbgpnat">true</profile>
> >> <profile namespace="karajan" key="jobthrottle">21</profile>
> >> <profile namespace="karajan" key="initialScore">10000</profile>
> >> <profile namespace="globus" key="jobsPerNode">1</profile>
> >> <profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
> >> <profile namespace="globus" key="slots">1</profile>
> >> <profile namespace="globus" key="maxTime">900</profile> <!-- seconds
> >> <profile namespace="globus" key="nodeGranularity">64</profile>
> >> <profile namespace="globus" key="maxNodes">64</profile>
> >> <workdirectory>/home/jonmon/swift.workdir</workdirectory>
> >> </pool>
> >> </config>
> >> tc
> >> surveyor echo /bin/echo INSTALLED INTEL32::LINUX
> >> surveyor cat /bin/cat INSTALLED INTEL32::LINUX
> >> surveyor ls /bin/ls INSTALLED INTEL32::LINUX
> >> surveyor grep /bin/grep INSTALLED INTEL32::LINUX
> >> surveyor sort /bin/sort INSTALLED INTEL32::LINUX
> >> surveyor paste /bin/paste INSTALLED INTEL32::LINUX
> >> surveyor wc /usr/bin/wc INSTALLED INTEL32::LINUX
> >> swiftscirpt
> >> type file;
> >> app (file o) echo()
> >> echo "Hello World!!!" stdout=@o;
> >> file output<"hello.txt">;
> >> output = echo();
> >> _______________________________________________
> >> Swift-user mailing list
> >> Swift-user at ci.uchicago.edu
> >> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
More information about the Swift-user mailing list
