[Swift-user] Montage+Swift+Coasters
Ketan Maheshwari ketancmaheshwari at gmail.com
Thu Jan 19 18:49:45 CST 2012
Emalayan,
>From your symptoms, it seems you are facing the same issue as I've been.
Could you tell more about the amount of data that needs to be staged to run
the Montage stages during which these warnings turn up? How much time
elapses since the start of your workflow after which you see these messages?
Also, what version of Swift is this?
Ketan
On Thu, Jan 19, 2012 at 5:51 PM, Emalayan Vairavanathan <
svemalayan at yahoo.com> wrote:
> Dear All,
>  I have a problem in running Montage with Coasters (in our local cluster
> - no batch schedulers). After few stages the swift run-time continuously
> prints the warnings below. Any ideas ? Should I increase the heartbeat
> count ?
> Everything works fine when I try to run the same montage-scripts with
> swift on a single machine.
> Thank you
> Emalayan
>  2012-01-19 15:38:09,207-0800 WARN  Command Command(119, HEARTBEAT):
> handling reply timeout; sendReqTime=120119-153609.206,
> sendTime=120119-153609.206, now=120119-153809.207
> 2012-01-19 15:38:09,207-0800 INFO  Command Command(119, HEARTBEAT):
> re-sending
> 2012-01-19 15:38:09,209-0800 WARN  Command Command(119, HEARTBEAT)fault
> was: Reply timeout
> org.globus.cog.karajan.workflow.service.ReplyTimeoutException
>         at
> org.globus.cog.karajan.workflow.service.commands.Command.handleReplyTimeout(Command.java:288)
>         at
> org.globus.cog.karajan.workflow.service.commands.Command$Timeout.run(Command.java:293)
>         at java.util.TimerThread.mainLoop(Timer.java:534)
>         at java.util.TimerThread.run(Timer.java:484)
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120119/0d8d3b5a/attachment.html>
More information about the Swift-user mailing list
