[Swift-user] Montage+Swift+Coasters
Emalayan Vairavanathan
svemalayan at yahoo.com
Thu Jan 19 17:51:15 CST 2012
Dear All,
I have a problem in running Montage with Coasters (in our local cluster - no batch schedulers). After few stages the swift run-time continuously prints the warnings below. Any ideas ? Should I increase the heartbeat count ?
Everything works fine when I try to run the same montage-scripts with swift on a single machine.
Thank you
Emalayan
2012-01-19 15:38:09,207-0800 WARN Command Command(119, HEARTBEAT): handling reply timeout; sendReqTime=120119-153609.206, sendTime=120119-153609.206,
now=120119-153809.207
2012-01-19 15:38:09,207-0800 INFO Command Command(119, HEARTBEAT): re-sending
2012-01-19 15:38:09,209-0800 WARN Command Command(119, HEARTBEAT)fault was: Reply timeout
org.globus.cog.karajan.workflow.service.ReplyTimeoutException
at org.globus.cog.karajan.workflow.service.commands.Command.handleReplyTimeout(Command.java:288)
at org.globus.cog.karajan.workflow.service.commands.Command$Timeout.run(Command.java:293)
at java.util.TimerThread.mainLoop(Timer.java:534)
at java.util.TimerThread.run(Timer.java:484)
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120119/620db259/attachment.html>
More information about the Swift-user
