[Swift-user] Question re: reliance on proxy cert
Jonathan Monette
jonmon at mcs.anl.gov
Wed Jan 18 12:42:09 CST 2012
Using jobmanager="ssh:pbs" starts coasters on the remote side using ssh to get to the remote machine. Coasters still needs a proxy to validate with.
On Jan 18, 2012, at 12:33 PM, Thomas Uram wrote:
> I'm using coasters with ssh:pbs and have the proper bits in ~/.ssh/auth.defaults to support authentication, but when I run the script it fails due to a missing or expired proxy cert:
> Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could not submit job
> Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could not start coaster service
> Caused by: org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException: org.globus.gsi.GlobusCredentialException: [JGLOBUS-5] Proxy file (/tmp/x509up_u1154) not found.
> Caused by: org.globus.gsi.GlobusCredentialException: [JGLOBUS-5] Proxy file (/tmp/x509up_u1154) not found.
> Why does it fail when an alternative authentication mechanism is available that would succeed? Is there an option to control this?
> The complete log is here, which includes the Swift script and the sites file.
> http://www.ci.uchicago.edu/~turam/hostname-20120118-1128-z3xo7eg9.log
> Thanks,
> Tom
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120118/4ba993ff/attachment.html>
More information about the Swift-user
