[Swift-user] coaster-service.conf
Emalayan Vairavanathan
svemalayan at yahoo.com
Mon Feb 27 22:59:20 CST 2012
So the start-coaster-service for cobalt uses cqsub and not qsub. qsub
has the --kernel option while cqsub has the -k option. Looking at the
man pages they seem to be the same, but not sure. Justin can probably
provide more information on the difference, or point to a document that
explains when one should be used over the other.
>> Thank youvery much for fixing it Jon. I am not sure about the trade-offs though. I can switch to cqsub if it is necessary.
Then Justin will have to do a svn up tomorrow for you. We probably
should figure out a way for you to have your own stable copy to make
changes too, so that us updating that copy is not a blocker for you
progressing further.
>> Yes. We need to talk about this in Wednesday meeting.
Justin could you please take an update ?
Thank you
Emalayan
To: Emalayan Vairavanathan <svemalayan at yahoo.com>
Cc: swift user <swift-user at ci.uchicago.edu>; "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>; MosaStore <mosastore at googlegroups.com>
Sent: Monday, 27 February 2012 7:39 PM
Subject: Re: [Swift-user] coaster-service.conf
On Feb 27, 2012, at 9:06 PM, Emalayan Vairavanathan wrote:
Hi Jon
>Thank you very much. Please find my ans below.
>I assume you mean the "-k" option in the cqsub command.
>What I meant was "--kernel" option in qsub.
So the start-coaster-service for cobalt uses cqsub and not qsub. qsub has the --kernel option while cqsub has the -k option. Looking at the man pages they seem to be the same, but not sure. Justin can probably provide more information on the difference, or point to a document that explains when one should be used over the other.
>Are you using your own checkout of trunk or the one in Justin's home directory?
>Code from Justin's home directory
Then Justin will have to do a svn up tomorrow for you. We probably should figure out a way for you to have your own stable copy to make changes too, so that us updating that copy is not a blocker for you progressing further.
>Emalayan
>________________________________
> From: Jonathan Monette <jonmon at mcs.anl.gov>
>Sent: Monday, 27 February 2012 6:13 PM
>I assume you mean the "-k" option in the cqsub command. So currently this is hard coded into the start-coaster-service script, it always uses zeptoos. I have made a quick change that uses a KERNEL variable that needs to be set in the coaster-service.conf file. Are you using your own checkout of trunk or the one in Justin's home directory?
>On Feb 27, 2012, at 7:33 PM, Emalayan Vairavanathan wrote:
>Hi All,
>>When I launch coaster-service, it allocates job with default kernel profile "zeptoos". I want to change the profile to"zepto-vn-eval/mosatest".
>>How can I do this ? Is there any configuration parameter available to change qsub command?
>>If so how I can specify / pass this parameter? (via start-coaster-service's command-line parameter or via a setting in coaster-service.conf)
>>Also could you please tell me the exact format ? Please point to me a document if there is any.
>>Thank you
>>Emalayan
>>_______________________________________________
>>Swift-user mailing list
>>Swift-user at ci.uchicago.edu
>>https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120227/7ccbc683/attachment.html>
More information about the Swift-user
