[Swift-user] coaster-service.conf
Jonathan Monette jonmon at mcs.anl.gov
Mon Feb 27 21:39:14 CST 2012
On Feb 27, 2012, at 9:06 PM, Emalayan Vairavanathan wrote:
> Hi Jon
> Thank you very much. Please find my ans below.
> I assume you mean the "-k" option in the cqsub command.
> What I meant was "--kernel" option in qsub.
So the start-coaster-service for cobalt uses cqsub and not qsub.  qsub has the --kernel option while cqsub has the -k option.  Looking at the man pages they seem to be the same, but not sure.  Justin can probably provide more information on the difference, or point to a document that explains when one should be used over the other.
> Are you using your own checkout of trunk or the one in Justin's home directory?
> Code from Justin's home directory
Then Justin will have to do a svn up tomorrow for you.  We probably should figure out a way for you to have your own stable copy to make changes too, so that us updating that copy is not a blocker for you progressing further.
> Emalayan
> From: Jonathan Monette <jonmon at mcs.anl.gov>
> To: Emalayan Vairavanathan <svemalayan at yahoo.com>
> Cc: swift user <swift-user at ci.uchicago.edu>; "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>; MosaStore <mosastore at googlegroups.com>
> Sent: Monday, 27 February 2012 6:13 PM
> Subject: Re: [Swift-user] coaster-service.conf
> I assume you mean the "-k" option in the cqsub command.  So currently this is hard coded into the start-coaster-service script, it always uses zeptoos.  I have made a quick change that uses a KERNEL variable that needs to be set in the coaster-service.conf file.  Are you using your own checkout of trunk or the one in Justin's home directory?
> On Feb 27, 2012, at 7:33 PM, Emalayan Vairavanathan wrote:
>> Hi All,
>> When I launch coaster-service, it allocates job with default kernel profile "zeptoos". I want to change the profile to "zepto-vn-eval/mosatest".
>> How can I do this ? Is there any configuration parameter available to change qsub command?
>> If so how I can specify / pass this parameter?  (via start-coaster-service 's command-line parameter or via a setting in coaster-service.conf)
>> Also could you please tell me the exact format ? Please point to me a document if there is any.
>> Thank you
>> Emalayan
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120227/aa5717ae/attachment.html>
More information about the Swift-user mailing list
