[Swift-user] swift on midway: apps and modules
Neil Best
nbest at ci.uchicago.edu
Mon Dec 3 18:07:17 CST 2012
On Thu, Nov 29, 2012 at 5:04 PM, David Kelly <davidk at ci.uchicago.edu> wrote:
> Hi Neil,
> It could possibly be something environmental. Are the modules loaded automatically when you log in through your .bashrc? If they are not already, could you give that a try?
> If that doesn't work, try editing sites.xml and try changing
> <workdirectory>/scratch/local/swift</workdirectory>
> to
> <workdirectory>/project/joshuaelliott/narr</workdirectory>
> Then try the run again and let me know when it's finished. That will just make some extra debugging information available that might better explain why it's failing.
> Thanks,
> David
Everything was basically working except that my project directory
became too cluttered with temp files so I changed the workdirectory
back to /scratch/... and now swift is failing with that "exit code
127" message again. What's the correlation between workdirectory and
module/PATH problems? Or is there something else going on here?
More information about the Swift-user
