[Swift-user] Error message on Cray XE6
Lorenzo Pesce lpesce at uchicago.edu
Tue Apr 17 14:28:19 CDT 2012
Thanks a lot. I will add the advres to the script, test it and add it to the swift on Beagle lecture.
I have tested the scalability and it seems to work. I set checks for job size and length and set automatic resize to fit into the requested queue (with message to the user about it).
On Apr 17, 2012, at 12:28 PM, Jonathan Monette wrote:
> To use a reservation on Beagle you would need to use the following line:
> <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24;pbs.resource_list=advres=res.id</profile>
> You have to use the pbs.resource_list in the providerAttributes key.  I did not using pbs.resource_list as the key though.
> On Apr 17, 2012, at 12:14 PM, Justin M Wozniak wrote:
>> On 04/17/2012 12:08 PM, Jonathan Monette wrote:
>> For reservations on Beagle, I think you can set profile
>> globus:pbs.resource_list to advres=reservation_name.number
>> The point is to set the pbs.resource_list to whatever needs to go after
>> #PBS -l ...
>>> There is a site file entry for that.
>>> <profile namespace="globus" key="queue">scalability</profile>
>>> You must make certain that the shape of your job fits in the queue you requested. If it does not fit, there is a silent failure and Swift hangs.
>>> On Apr 17, 2012, at 11:58, Lorenzo Pesce<lpesce at uchicago.edu>  wrote:
>>>> Works great!
>>>> Is there a way I can ask swift to put me in a specific queue, such as scalability of some reservation?
>> Justin M Wozniak
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120417/be24a56b/attachment.html>
More information about the Swift-user mailing list
