[Swift-user] OS X dependencies
Gustav Larsson
larsson at uchicago.edu
Sat Apr 14 19:37:34 CDT 2012
Hi Jonathan,
Thanks for your quick reply!
I tried this both with the trunk and 0.93.
Just to clarify, it was <absolute path>/cog/modules/swift/dist/swift-svn/bin that I added to my PATH.
Gustav
On 2012/04/14, at 19:20, Jonathan Monette <jonmon at mcs.anl.gov> wrote:
> What source are you building? Trunk? 0.93?
> Also, are you sure you added the right bin directory to your path? After a build you need to add dist/swift-svn/bin
> On Apr 14, 2012, at 19:02, Gustav Larsson <larsson at uchicago.edu> wrote:
>> Hi,
>> I am trying to run Swift from a source build on OS X (10.8, dev
>> preview 2 / Java 1.6.0_31). The ANT build was successful and I added
>> the swift/bin to my PATH, so that I can run it. My problems however
>> are runtime errors:
>> 1.
>> Exception in thread "main" java.lang.NoClassDefFoundError:
>> org/griphyn/vdl/karajan/Loader
>> So, I went ahead and added karajan/build to my CLASSPATH. Fixed.
>> 2.
>> Two more errors like this, resulting in adding swift/build and
>> util/build as well to my CLASSPATH. Fixed.
>> 3.
>> com/thoughtworks/xstream/converters/Converter
>> Now, I could probably download xstream and get this to work, but
>> talking to Mike Wilde, he seemed puzzled that I should have to go
>> through this process, so is there something I'm missing?
>> Thanks!
>> Regards,
>> Gustav
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
